Does Gyeon Primer polish stain trim?
bigez
Does anybody know if Gyeon Primer Polish stains trim? I want to remove Optimum Gloss Coat and put on some Mohs. Was going to use Hyper Polish, but thought it might be better to use Gyeon's Primer since I'm going to Mohs.
AND, do you think Primer is enough to remove whatever Gloss Coat is left? Probably just use a black or white LC pad.
Thanks!
Primer stained some of the black trim on the roof (two black strip pieces that run front to back along the roof on sides).
You can use hyper polish with no issues. I would just use that, panel wipe and coat. It’s a good polish.
