I don't think that porter cable with a wool pad will be enough. If able to I would at least get a Flex 3401 with a yellow foam or purple wool foamed pad
Good luck with a PC. You are more brave than I. I'm dreading using my 3401 with yellow pad on a 26' I have coming up this weekend. I do have a rotary and one wool pad but I'm not gonna swirl-o-matic it then have to polish again.
So what about the scouring pad with the heavy compound on the da polisher after? Any thoughts?
Thanks, I guess I didnt really just ask, is it a bad idea to use the light scouring pad and the following it with the heavy compound on a wool pad?
Just some really fine sandpaper with a foam backing I got at local marine shop
