DP 4 in 1 as quick detailer
Never tried it, but looking to use it. There are several of us who use Optimum No-Rinse as a QD and I can tell you that it works great. Better cleaning power than most QD's and the same shine and brightness.
I'm sure that DP 4in1 used as a QD would give the same results....just gotta jump on that BOGO.
it does its job. It's not the best, but after all, it's a pretty good bang for the buck... DP, or Optimum No Rinse...
It should be looked at as more of a cleaner quick detailer than one to add gloss. I would also recommend playing with the dilution ratio a bit as it some found it works better with a lighter dilution ratio.
