DP Carpet and Upholstery Cleaner
sullysdetailing
DP Carpet & Upholstery Cleaner lifts stains out of carpet and fabric using the latest advanced surfactant technology.
Pro: I have yet yo find a carpet that is to dirty or soiled for this stuff. It does an excellent job cleaning the carpets and bringing even the dirtiest carpets to like new condition.
Cons: Some carpets might require a second wash or let the product duel for a 1-2 minutes before scrubbing.
Before:
After:
Elbow Grease and shop-vac. The bottle says to spray on the carpet scrub and pat the carpet dry. I like to use the shop-vac, then wet the carpet, let it soak 1-2 minutes, scrub, rinse, shop-vac
Do you just rinse with a damp towel?
Looks great by the way!
how did you get those nice extractor lines in it. also I know sometime when I spray the cleaner on the carpet and scrub and doesnt come out and becomes sticky and discolor. how do I get that out or am I using too much. I dont think I am.
+1
Sounds like you do a lot of detailing. You don't ever use a hot water extractor? Just curious.
now how do wet the crapet without soaking the interrior carpet. when you say wet do you mean wet with the cleaner or wet with water. what do you wet it with? when I do this it leaves shoap and sticky stuff in the carpet I cant get out. you know after doing this good of work you would have to explain.
You remove the carpets.
If I cam cleaning the interior carpet not the matts I do not wet them. Just spray a little product on the carpet scub, pat dry, vacuum
