DP Cleanse-All
Jeff120
This stuff is the bomb!
DP Cleanse-All Exterior Cleaner works as a bug & tar remover, a wheel cleaner, a tire cleaner, an engine degreaser, a convertible top cleaner, a vinyl
Used it today for the first time. I have white letter BFGs on my truck that can a times be a little tricky to get clean, esp when really dirty. I normally use Megs APC+ and it works pretty well on my wheels and tries. OPT power clean @ 3:1 needed a second pass to get them clean. Blech white used to be my go to for the white letters. A few weeks ago I tried ARO and it worked well, but with the DP everything in the wheels and tires just melted right off. Even more so then with any other product that I have ever used.
The con of this product is its a little expensive.
For those of you that use this cleaner do you dilute it? Im going to try experimenting with it at 1:1 and see how that does. Any other suggestions?
Def. recommend as a great cleaner.
