DP Odor Eliminator
Ted S.
I like this stuff a lot. Just a few short sprays does a good job!:xyxthumbs:
I still have my first can of the Tropical Breeze that I've been using here and there since the DPOE first came out. One can goes a loooooong way if you aren't using it for commercial purposes.:dblthumb2:
Seems like it was one of those flavor of the month items, however. Seems to have fallen off the raday for quite some time.
How long does it last? I have been using Febreze Odor Eliminator on interiors but it doesn't last that long.
A day or two. Odors dissipate fairly quickly. The "scent durability" is fairly short, but it does eliminate odors until they reappear.
For example, this morning I treated my small bedroom. Sprayed the DPOE in the room, and closed the door. After two hours, I aired the room out for about two hours. The "Tropical Breeze" scent was lessened quite a bit as a result of opening the window to air the room out. But, the stale vacuum odor that was present before the treatment completely disappeared, and that was 13 hours ago.
I think its longevity is dependent on stochastic variables.:props:
i was graciously gifted some of the new leather scent from an autogeek contest, stuff does work great for eliminating odors, works so good im bringing it on the bus with me to mask the toilet odors if i need to go, something that isnt rough on the nose LOL, but for autos stuff works great i fogged out my car manually and eliminated all odors, the leather smell stayed for a few days but the other smells were gone pretty darn effective, however there is a downside i do not like how it will lock if you push too hard, but i know its there to fog. i just made the mistake inside and locked it down LOL luckily i know how these caps work and just popped it off and stopped the fogging so i switched it out to a clean spray paint nozzle, works better for how i use it....nozzle would not have locked down if the white dispenser nozzle was alittle taller meaning less pressure to dispense the product, that would be the only "issue" i have with it. great product however.maybe ag could get larger cans and switch nozzles to a normal spray..who knows what will come in the future!
Stochastic:
:dblthumb2::dblthumb2::dblthumb2:
:applause::applause::applause:
:urtheman:
Ars Conjectandi being demonstrated at one of its finest moments!!!
Thanks.
