PaulMys
Active member
- Jan 14, 2014
- 10,772
- 1
Got to try the DP Waterless today.
Truck had been washed w HyperWash on Friday. Yesterday we had some nasty wind and rain, and the truck had dirty water spots all over it.
*Description: DP Waterless Auto Wash uses a high lubricity formula to gently, yet effectively, remove dirt, dust, oils, and other above-surface contaminates from your vehicles paint, glass, chrome, plastics, and metals. Further enhanced with UV protectant, DP Waterless Auto Wash leaves behind an extra layer of protection while also enhancing the existing gloss. No bucket, water, or hose required!
*Directions: Liberally spray the surface to be cleaned and wipe away using plenty of clean MF towels. Flip your towel to a clean side and buff away excess product. Continue around entire vehicle.
I have to say that I am impressed with this. It smells great (tangerine?) and it is pretty slick. But, the real test is in the cleaning. The DP gets an “A” in this category.
Definitely something to consider if you need a good waterless product. I would also not hesitate to use this as a clay lube.
Thanks to Meghan for sending me this to try out. It did not disappoint!! :dblthumb2:
