DP Xtreme Foam
sullysdetailing
If you are looking for an all around great car wash soap that works equally well in the foam gun as it does in your wash bucket this is the soap for you. I wash and detail tons of vehicle and I have recently switched to a local company call Ardex because they are down the street and i can get 5 gallons of soap for $35. But the dilution ratio is 1oz per gallon, while DP Xtreme foam only needs 3 per 5 gallons.
Now I was happy with Ardex wash and wax soap for normaly car washes but when it came to using it in the foam gun it sucked and required so much soap to foam that it would stripe the vehicles wax. Now it is a little better in the foam cannon but it still required to much soap.
Now this is when I decided to get some DP Xtreme Foam just to use in the Foam Gun since the ardex soap is cheaper to use for the wash process. Well that didn't last very long. After I put it in the foam gun to start the detail I decided to use it in my was bucket as well. That wasn't such a good idea, it made me fall in love with this soap all over again and I went through a gallon in 2.5 week lol
What I like about DP Xtreme Foam is that you get a great amount of foam and cleaning power yet it is gentle enough not to stripe wax or sealant from the vehicle.
If you are looking for an all out great soap for your foam gun/cannon and work just as well in your wash bucket DP Xtreme Foam is for you.
Thanks, Shawn...I'm fittin to pick some foam shampoo up. I'll keep this in mind! Thanks for sharing.
I first purchased DP extreme foam with my foam gun 2 years ago. I've tried a variety of substitutes and can't find anything that foams as well for guns and cannons.. Like you, I started using it in my wash buckets and it went faster than krispy Kream donoughts. I just purchased a a new foam cannon and waiting to Detail Fest to bring home more DP.
Just a heads up.. the CG Honeydew snow foam is amazing....
It really foamed like snow foam
I just used it the other day....
