Dr. Beasley deals and 15% off!
Elliot@Autogeek
*15% Off Coupon Code SERUM15 valid on in stock items. Not applicable on previously placed orders, custom or special order items, extractors, air compressors, BUY ONE GET ONE, VIP Special, car covers, polishers & polisher kits, vacuums, Kreepstool, FlatStoppers, Shop Air Heavy Duty Drum Fans, vapor steamers, garage flooring, gift certificates, bulk and case pricing, complete wash systems or any item as noted on product page. One coupon code per order.
*Free Shipping applies to orders over $75 with ground service within the 48 contiguous United States. Regular shipping charges apply to garage flooring and mats, air compressors, and carpet extractors as noted on those products. Regular expedited charges apply.
Dr. Beasley's Glass Serum Kit
[TD="align: center"]
[TD="align: center"] The Glass Serum Kit will make applying a glass coating to your vehicle easier than ever before by supplying you with everything you’ll need to do the job! Glass Serum is an incredible glass coating created by Dr. Beasley’s to make sure that your glass always looks its best, is properly protected, and sheets and beads water for years to come.
The Glass Coating Prep will perfect the surface of your glass to ensure that the coating is able to properly bond and provide the promised level of protection. The applicator and cloths that come in the kit are designed to make sure that the coating you are applying is applied in a consistent and even manner.
[/TD]
[/TD]
[/TD]
[/TD]
[TD="align: center"] Here's how it works..
The surface of glass is actually jagged and uneven at the microscopic level, with tiny hills and valleys that capture water and dirt. This is what often leads to etching and staining. To prevent this, Glass Serum bonds with your glass, filling in the nooks and crannies to leave contaminants with nowhere to go but off. After Glass Serum cures, your glass' surface energy will be lowered so it can repel liquids, while UV-inhibitors will keep your glass crystal clear for years to come.
[/TD]
[/TD]
[/TD]
[/TD]
[TD="align: center"] The application process
Before the glass surface can be coated, you have to first ensure you're treating a completely clean surface. Clean glass with an ammonia-free cleanser, like BLACKFIRE Glass Cleaner. [/TD]
[/TD]
[/TD]
[/TD]
Once the glass has been cleaned of fingerprints, dust, smudges, and any other contaminating films, use the Dr. Beasley's Glass Coating Prep (included in the Glass Serum Kit) to remove any other stubborn contaminants.
This step allows the coating to fully bond to the glass surface creating the hydrophobic and protective layer we've come to expect from glass and paint coatings.
After the surface has been prepped, it's time to coat! Apply several drops of Glass Serum onto the suede cloth-wrapped foam block applicator and start to apply to the surface using slow and precise movements along a vertical line.
Repeat with horizontal lines, creating a cross hatch pattern. This ensures maximum coverage.
Keep your glass coated and hydrophobic for years with Dr. Beasley's Glass Serum Kit!
Dr. Beasley's Glass Serum Kit FREE BONUS!
Our Price: $74.99
For a limited time only, receive a Dr. Beasley's AdvanceCoat: Glass 4 Pack FREE with your order!
$24.99 Value!
Dr. Beasley's Glass Serum Pro Kit FREE BONUS!
Our Price: $94.99
For a limited time only, receive a Dr. Beasley's AdvanceCoat: Glass FREE with your order!
$24.99 Value
Dr. Beasley's PlasmaCoat
Our Price: $39.99
For a limited time only, receive a Dr. Beasley’s AdvanceCoat: Gloss FREE!
$39.99 Value!
Dr. Beasley's Formula 1201 Paint Coating Free Bonus!
Our Price: $39.99
