Dr. Beasley's wheel products
Mike Hoekstra
I had the opportunity to use Dr. Beasley's Brake Dust Remover, Wheel Cleaner, and Wheel Seal on my last detail. Being the tester I am, I like to torture test products. The pickup lives outside all year. I only wet the wheel down with water. No high pressure rinse, or soap prior. After wetting the wheel, I sprayed on the brake dust remover and wheel cleaner and let them both dwell. The great part about both products is the gel-like consistency which sticks to the wheel and does not run off allowing it to dwell in place. After letting it rest for 5 minutes, I used a wheel brush to agitate the wheel, and rinse with water. The result was a clean slate. After finishing the other three with the same process, I went back around and applied the wheel seal as directed by spraying on a microfiber towel and wiping the wheel down, and buffing with a dry microfiber towel. Overall, I am impressed with the performance of the products. Particularly the gel consistency that lets it stick where it can work. Less product, more work, less waste. Bottom line, I would recommend them to other detailers.
I do not see the wheel seal in the AG store yet. I see the matte wheel seal. Good review of the products.
