Dr.color chip paint match
asap2stacks
The paint code clearly states "ZY" on the sticker, but you are correct. That vehicle surely doesn't look like Oxford White as Dr. Colorchip reports. It looks more like HJ Pewter Metallic. You may have to have the dealer run the vin and get the correct paint code. Perhaps even check another location on the vehicle (dash board near the windshield / drivers side) where the vin is imprinted and make sure they match.
I actually had a discrepancy on "YEAR" on my EcoBoost Mustang. Window Sticker said 2016, however, two different insurance companies, including State of NH and State of AZ both claimed it was a 2017.
You'll either need to talk to a body guy or ford parts guy. Ford Parts should be able to pull it up by VIN. (Parts guy will just be a phone call).
On another note, you'll probably want to squirt and squeegee that bumper cover. Bumper covers are tricky with Dr. Color chip. I've seen at times where product is a little too thin and won't adhere to the plastic.
Good luck!
Good luck!
Was going to sand then apply let dry then buff and prolly little more sanding
CCCoating
