Drying aid mixture - Wolfgang Uber - SONAX BSD
5js
My order from AG should arrive today. I am planning of trying a mixture of Wolfgang Über Rinsless Wash and SONAX Brilliant Shine Detailer as a drying aid and quick detailer.
Any suggestions on the ratio’s? Was planning on mixing 3 oz of Wolfgang Über Rinsless Wash in a gallon of distilled water (waterless ratio). Then I was going to take and mix 1:1 with the SONAX BSD.
Does this sound like a good ratio to try?
WGU is VERY concentrated, that ratio is too much. When I used it I'd go with 1 oz per 2 gallons but always used 2 ounces because I would make 4 gallons of cleaning solution so I had extra to fill my 1000ML Kwazzer for pre-treating each panel.
There's no need to use distilled water for the wash either unless you've got hard water, city tap water has always worked well for me with WGU, as well as all other RW products.
Are you throwing a bunch of mf towels into the bucket or using a grout sponge to wash the car? Pre-treating is a must for which ever method you chose.
Btw, your right on target with BSD being diluted 1:1 but you don't have to use it each and every wash, well, unless you've got the money, LOL. Using WGU will give you a great shine on the paint and some protection as well, this is why I'm saying what I'm saying about using BSD.
Klasse - I should clarify, this is not a mix for a rinseless. I'm just mixing as a drying aid/quick detailer for now. I might try mixing for a rinseless in the future.
Oh ok, gotcha but in that case, 1 oz of WGU in a gallon of distilled is all you need for a drying aid, no need to add BSD if I'm honest. BSD diluted 1:1 makes a great drying aid by itself actually.
Well I ordered both, so maybe I'll compare them each on their own - then at a 50/50 mix to see what differences I see.
Are you ordering a gallon of WGU or the small bottle with the measuring device built in? Also, are you just using it as a drying aid? I ask because it's one of the top 5 RW on the market today, period and you'll love it when doing a RW
I ordered the 16 oz with the measuring device built in to test the product. For now, just as a drying aid and quick detailer. I live in Maine so for the winter I plan on going to a coin-op bay and washing and rinsing then misting on Uber/BSD as a drying aid (drying with Griot's PFM towels). About the best I can do through the winter. When temps are better in the spring I'm gonna mix as a rinseless and give that a try. I have some different MF towels for doing a rinseless.
Using BSD mixed in to your drying aid will definitely add regular protection for you.
5js
I did what you are thinking of doing only I used Meguiars d-156 x-press spray wax and WGU.
After mixing 3oz of WGU to one gallon of distilled water I then made a concoction of 2parts WGU
to 1part M-156. I think it is awesome but I'm also very new and don't have a lot of experience with a lot
of different products.
I would think Sonax would work just as well or probably better. You got both coming so give it a go. It seems like everyone
throws so much different products together in layers that I don't see how it could hurt. Looking forward to
hearing your report.
5js
I doing a full detail on a new car - then I'll be using the mix as a QD for a while, then next wash I'm gonna try the same mix as a drying aid. I'll post observations, though being new I won't have a lot to of experience to evaluate it against.
WGU works fine at temps in the upper 30's, just sayin'
Agreed - anytime it's over freezing and sunny on a weekend in the winter - I'll use WGU to RW the cars - no issues.:props:
If they are really covered in salt and it's too cold I simply hit the Self Sprayer bay at the car wash first and drive out and RW there (I can generally do the car in 15 min):buffing:
Both my winter cars are coated (M37 on one / CQv3 on the other):dblthumb2:
upper 30's....if it got that warm I'd be hitting the beach :laughing: Average high in January for me is 25F, average low is 2F.
We'll see how it goes. I do lose my garage to my toys (motorcycle, ATV, etc) during the winter. l have a plan for the coin-op bay for a wash/rinse and WGU/BSD as a drying aid. If I get a nice day I may try a rinseless wash.
I have tried mixing BSD with everything. Yeah I know that makes Bob cringe. But I have found that simple is sometimes better.
As a drying aide is use BSD 1:1 with distilled water. Thins it out so it is easy to work with and doesn’t diminish the BSD performance.
A guy in Germany tried every dilution with water and 1:1 allows the best performance and use. Its on YouTube somewhere.
Sorry for a dumb question:
Can you please explain to me how/when you use the product as a "drying aid"? Are you applying this to the wet car after washing it but BEFORE drying the sitting water beads? Are you then absorbing the detailer as you absorb the water? Or are you applying the detailer AFTER you have wiped the water off the panel?
Thx
Thx
While the car is still wet. Spray on the panel and it will add extra lubrication to avoid any towel marring. Also adds extra gloss and protection. Can use some as simple as an over the counter quick detailer or a spray wax/sealant.
Sent from my SM-G975U using Autogeekonline mobile app
Thanks for clarifying. I have been going over the car with Durawax or Wolfgang Spritz, but I've been doing it after I dried the car. I'll try it as I dry.
Thanks
Thanks
Drying aid makes drying much easier, besides just safer, and reduces your efforts of drying AND topping with a spray into a single effort. Good stuff.
Detailed my new car this past weekend - washed/dried -> decomtaminated -> rinsed/dried -> clayed -> polished -> sealant.
I wanted to do my door jams with my 50/50 mix of Uber and BSD. I didn't like it as a QD. Was WAY to grabby and I could see a lot of the microfiber cloth getting pulled onto the surface. Swapped over to the straight Uber mixed at 3oz/gallon. Was quite impressed. Easy to apply and made all the door jams look perfect.
Maybe the 50/50 mix would work on the paint with sealed with the Menzerna Powerlock - but it didn't work for me on the non-sealed surfaces. I will still try it as a drying aid sometime.
