The Cobra Waffle Weave Guzzler is available in sizes Regular, Supreme, and Ultimate.
To be a little more specific, the sizes are 16" x 24", 20" x 40" and 28" x 44".
I haven't used the dry me crazy towel. Just wondering why were you not impressed?
The chemical guys wooly mammoth towel works really nice. I was hoping dry me crazy towel would be even better...
I use Cobra guzzler hd (it has a foam in between the waffle material), a must have
The Mothers Performance Drying Towel is an HD on steroids. Bigger , thicker foam and nicer banding. Trust me on this. I gave my HDs away when I tried the Mothers. It is 20 x .24. The Dry Me Crazy is my other favorite.I use Cobra guzzler hd (it has a foam in between the waffle material), a must have
Not my question but I hope you don't mind my answering. I use my Mothers dry. I lay it on the surface. The foam makes it lay down perfect every time. I hold the towel with one hand and pat dry with the other. No towel movement so no towel marring. I do this most often with Rinseless. One towel can do an Expedition!Do you use it dry or slightly damp? Feed back please. :buffing:
The cobra guzzler HD is just 16" X 24" in size whereas cobra supreme guzzler is 20" X 40" in size...Even though the guzzler HD is smaller in size it absorbs more water than the supreme guzzler??
