Dual Action Buff out of Orange Peel - Advice Request
I get e-mails all the time from people with questions about detailing their cars. While I prefer people to join our forum, become part of our community and then post their questions to the forum I know not everyone in the world is going to do this so I always do my best to share the nutshell version of an answer I would invest the time and resources to type out if I were typing on the forum.
That's because you can do so much on the forum and so little in an e-mail and typing time is limited.
Wes said:
Hello Mike.
I have been a follower of your forum posts and I am an owner of your DVD's on detailing. I have a comparison question that I cannot find the answer to.
Background: I painted my Willys Jeep hood and front fender in a two stage metallic basecoat then clearcoat. My clearcoat has come out with a fine textured orange peel (likely due to using too small a gun nozzle - used 1.0mm should have used 1.4mm like the specs showed).
I could do three things now:
1) wet sand and respray clear coat - I have 3 good coats of clear so I dont need more , and I cannot guarentee I wont get orange peel back
2) wet sand 1500, 2000, 3000, rotary buff with wool pad/cutting products, followed with DA portercable polishing - problem is I don't have a variable speed rotary tool nor wool pad, so there's additional cost and I'm not an expert with rotary buffing, however I am a fast learner and have plenty of experience with handling grinders/polishers. I'm not too worried about trying this.
3) DA portercable with Procar Denim pad, then progressively less agressive polishes/pads - I have everything I need except the denim pads. This seems like the obvious choice, however would the result be similar to the wool pad on the rotary buffer?
So, in a nutshell, should I rotary buff with a wool pad or DA with a Denim pad? Thoughts?
Regards
...Wes
Hi Wes,
The Denim pads will be the safest route and as long as you're not in a hurry you can take your time and buff and buff and buff till you're happy.
The most effective and fastest route would be to wetsand and then use a wool pad on a rotary buffer with a quality compound to remove your sanding marks.
If it were mine, I would machine sand using a combination of 3" and 6" Trizact discs from 3M as well as some 3M Blue Vinyl Tape to protect any raised body lines or edges.
You can also hand sand but as I teach in my detailing boot camp classes in the wetsanding portion, the sanding marks left by hand sanding take longer to remove and you end up removing more paint and you often end up with tracers.
Just the opposite for machine sanding. The sanding marks buff out fast, less risk of heating up the clear coat, less chance of pigtails and you leave more paint on the car.
I only hand sand when I cannot machine sand.
The Griot's Garage 3" polisher makes a GREAT machine damp sander and the PC works great for the 6" discs.
With the Denim Pads it's really just a matter of working small sections and doing a lot of buffing but it's a lot safer as there's a lot less risk and you need a lot less skill and investment to do the job.
I'd also recommend joining our forum so you can interact on it. This forum is akin to any tool in your tool chest as that's what it is... a tool to help you get the results you're working for.
Click here to become a member of AutogeekOnline!
I love having this forum as a resource.
Mike, I remember the video you posted using the denim pads on the PC. I picked up a couple to play with, based on that video.
OK Mike, here's a variety of questions, maybe you can help me and others...
I myself know of only one maker of such Denim Pads, Carpro.
But, some things I've noticed, even at Carpro's site, they list 3 different sized Pads for the more aggressive Compounding, but only one size "Velvet" Pad for polishing?
I've inquired to Carpro why this is a few days ago, but have gotten no reply. Understandable at this time of year, the Holidays are upon us, and us folks hopefully would be able to find some small R&R during this time.
Another question? Are there others out there who make such Denim Orange Peel Pads besides Carpro?
Me, I see such pads as a very valuable tool in the right hands. I know you often teach to "not work backwards".
My recent thoughts about working backwards, is, here comes a practically new 2014-2015 vehicle, let's say a Ford Focus, the finish is loaded with nasty orange peel. Reflections are virtually nil, the finish is looking fairly poor.
I'd assume I wouldn't want to start taking wet papers to finish, and just wipe out ten years of wear and tear to the clear coat, in effect turning a relatively new vehicle into a 10 year old thin finish by such aggressive means.
That I'm liking the idea of removing orange peel while also smoothing the finish adding gloss. In other words, I'm working "forward", killing two birds with one stone.
I'm of course aware that simple DA'ing, or Rotary Polishing does smooth the paint, levels the surface, things most likely will not look worse in the end with more simpler finishing tasks, but on the other hand, will not achieve the best finish that any applied paint system can achieve per given vehicle.
Please advise, thanks,
Mark
The Velvet pads are somewhat conformable.
The Denim pads are thin and do not conform to contours at all. I used the 5.3" and 3" on my SUV
The DOI with the Denim pads is not as good as with wet sanding
It takes longer
The Denim pads are safer as the removal of CC is slower
We were using them on my truck down at Meguiar's TNOG and had a PTG and an infrared thermometer. They do heat up, but less than a foam pad on a rotary. They have some sort of magical quality that we saw, where the paint was being leveled, but the PTG would hardly budge. I can't remember what the total removes was, but it was way leas than anyone expected
The 1/8" 3M Vinyl Tape is an absolute must when using Denim pads
The Denim pads hated FG400, but loved M100
Expect short working times and lots of dust
It takes longer
Thank you for your observations and experiences.
May I ask why the particular use and selection of 1/8" 3M Vinyl Tape? I'm guessing taping is needed due to possible trim damage with these more aggressive Pads? Is it that the Vinyl Tape stays put better than other conventional Tapes?
I myself know of only one maker of such Denim Pads, CarPro.
I've inquired to CarPro why this is a few days ago, but have gotten no reply. Understandable at this time of year, the Holidays are upon us, and us folks hopefully would be able to find some small R&R during this time.
My guess would be that the Denim pads simply work better for removing paint and more sizes enables "you" the end-user to match the pad size to the panel for which paint is being removed. You certainly don't want to do this type of work and be buffing on a raised body line or an edge.
I use the Rupes TA50 with 2" sanding discs and the Griot's 3" polisher with 3" sanding discs for thin panels, tight areas and spot repair to completely reduce risk to an absolute minimum plus the superb control you have over small tools versus large tools.
Same idea would apply to removing paint with denim pads and a compound and keep in mind, CarPro recommends these for use with rotary buffer. I'm the guy that stepped outside the box and used them with the Porter Cable.
How to remove Orange Peel using a Porter Cable Dual Action Polisher
Another question? Are there others out there who make such Denim Orange Peel Pads besides CarPro?
Off hand I'm not sure...
That's kind of my way of thinking... there's benefits and drawbacks to sanding factory clearcoats. Mostly drawbacks because the FACTORY doesn't give you anything to work with. And as I show in this thread, factory paint is thin...
Paint is thin
The one benefit is if you know what you're doing and have confidence that some caveman detailer hasn't already butchered the car in front of you, machine sanding, that is damp sanding, keeps the surface cool and removes defects while leaving behind a very uniform sanding mark pattern that also buffs out fast and easy and thus keeps temperatures low.
I taught this technique when Meguiar's first introduced their Unigrit discs at Mobil Tech back in 2010. This was the first class ever taught to the public on these discs and this technique of removing defects using high grit sanding discs instead of the normal heavy compounding.
Pictures from Mobile Tech Expo 2010
Of course now days we have Trizact #5000 discs and for anyone that has never used these before, after sanding with them you actually start restoring gloss and the sanding marks buff out super fast and easy.
Check out the section of paint on the far right, this was sanded with #5000
Video: Wow! 3M #5000 Grit Polishing I mean Sanding Discs!
See how that last section is actually REFLECTING images?
(I think this was the first article posted to a forum on #5000 and this was in 2012)
That is the optimum idea for a process....
Mark
I agree with the last paragraph.
The person that started this thread by sending me an e-mail is simply looking for the best method for him to remove orange peel.
For the most part, I don't answer e-mail questions via e-mail. Typing time is too limited to type for one set of eyeballs. If someone e-mails me or PM's me questions I ask them to take it to the forum or I take it to the forum.
After I answer the question I send the person the link and encourage them to "join the forum" as that's where I interact. I leave it up to them however. I've sent the Wes the link to this thread and I'm confident he's read it and may read it into the future.
Some people are forum people while others are not. The nature of a forum is for a thread to sometime take on legs of it's own. If a person doesn't check on it more than once they may miss out on some good info. I have not control over that.
Big picture is this...
What Wes wants to do is a fairly complicated process where if a mistake is made it takes you back to point zero.
I shared the safest method to try and also the fastest and most effective method to try...
For a person that does not have sanding experience, or rotary buffer experience, nor all the tools and supplies to do it correctly, then moving along slowly with denim pads is a safe and good option.
Me?
I would machine sand that paint and then cut it with a wool pad and rotary buffer just like I did to this old 2-door Chevy....
How to wet sand a car - Time Lapse Video
Back in March of this year, (2013), I did a complete wet sand, cut, polish and even machine waxed a 1964 Chevrolet Malibu and while doing this project, Yancy set the GoPro camera up to take a picture every minute.
It's been in queue for editing since then but I'm happy to announce it's now been edited and uploaded to our YouTube Channel.
[video=youtube_share;5zDuFzvKSAI"]How to wet sand a car[/video]​
Here's the steps I followed...
Covered windshield using the Beach Towel Tip.
Covered interior and convertible top with Eco-friendly drop cloth.
Removed easy to access chrome emblems and script.
Wiped entire car down with Wurth Clean-Solve per what I wrote in post #5 here.
Taped-off all edges and raised body lines using 3M Blue Vinyl Tape. Tape-off video here.
Machine sanded all body panels using a 2-step system
First sanding step: I used 3M Trizact #3000 Grit Discs. I used 3" discs for thin panels and around edges and body lines. Used the 6" discs for the major flat sections of each panel.
Second sanding step: I used 3M Trizact #5000 Grit Discs. I used 3" discs for thin panels and around edges and body lines. Used the 6" discs for the major flat sections of each panel.
Removed all sanding marks.
For this I used the new Meguiar's M100 Pro Speed Compound with a LC Wool Cutting pad on the Flex PE14. At the time I did this project back in March of 2013 this compound had just been introduced to the market, so it was a new compound and I think this is the first car completely sanded and compounded and caught on video using M100 Pro Speed Compound. Speed on the Flex PE14 = 1000 RPM.
Removed any swirls left by the wool pad and the compounding step.
For this I used Meguiar's M205, the follow-up polish for M100 with a 6.5" Lake Country Flat Foam Polishing Pad on the Flex PE14. Speed on the Flex PE14 = 1000 RPM
Finish Polished to maximize gloss and ensure no holograms
After using the rotary buffer with the M205 I re-polished every square inch of paint using Pinnacle Advanced Finishing Polish with a 5.5" Lake Country Foam Flat Finishing Pad on the Porter Cable 7424XP on the 6.0 speed setting.
Machine Waxed
After wiping all the finishing polish off I machine applied Pinnacle Souveran Paste Wax using the Porter Cable 7424XP with a 5.5" Lake Country Foam Waxing Pad on the 4-5 speed setting.
Removed Wax
I removed the wax wearing microfiber gloves and using super soft rolled edge microfiber towels.
Comments....
I wanted to document not only the process but how long it would take me to do this type of project all by myself working non-stop. If you watch the video you'll see around the 4:47 time stamp that the car has now been turned around and is facing forward in the garage.
Here's what was going on...
While I did the actual work non-stop, as in once I started in the morning I did not stop till end of day, I did have to spread the work out over two days as I have too many other job duties to process outside of the garage.
The first day I sanded all the horizontal panels and the driver's side panels. The second day I turned the car around and only had to sand the passenger side.
In a number of places you'll see me standing while I either sand and buff or sitting on the floor while I sand and buff and the reason for this is we don't have a car lift in our garage and proper technique when sanding and buffing is to always be looking across from the paint you're working on. This is especially true when sanding and compounding. I always say,
If you can't bring the car up to you, (with a lift), then you have to lower yourself to the car"
The entire process from start to finish as I listed the steps above except for the initial wiping down of the car with a waterless wash and removing the chrome trim took me approximately,
12 Hours
I hustled the entire time. Only a few times did I stop to either take a water break, switch to different products or pads, or talk to someone that may have entered the garage.
I don't recommend ever trying to do this type of work in a hurry as you'll make mistakes so I didn't hurry but I did hustle. Time is valuable for all of us and I did this during business hours so another reason I had to hustle is because when working in the garage, other job responsibilities are on standby.
Besides this time-lapse video of completely sanding and buffing out an entire car, I think the first time this was ever caught on a GoPro camera using time lapse video was when a team of guys and myself did the full wet sand, cut and buff to a 1969 AMX in November of 2012 as documented in this thread,
Time Lapse Picture Capture of the 1969 AMX Nebraska Project
This was a fun project and I hope you enjoy the video.
Well hello Mike. I did join your forum. Thanks for your comprehensive reply. I am active on many forums but new to yours. Sometimes I am reluctant to post on forums so as to avoid getting flamed or the mis-guided advice for overconfident newbies. Obviously that's not the case here. Since you took the time to reply, I will take the time to document my success with some photos. (I'm not planning on failure. Wink). I have ordered the Procar denim and velvet pads from a Canadian distributor and I am waiting on their arrival. I know you use Meguiars, however access to their products is lousy here in Canada so I use Poorboys compounds. My plan will be to buff with the velvet pad (approx 3000 grit equivalent) SSR3 (M105 equivalent) at 6000 speed, then buff with SSR2 on an orange pad at 5000 speed, then polish win SSR1 on a white pad. Buffer is a dual action portercable. I don't think the orange peel is bad enough to start with the demon pad (equiv to 2000 grit - depending on the compound I suppose).
What compound do you suggest for the denim and velvet pads?
Regards
...Wes
Welcome to AutogeekOnline! :welcome
And you're welcome.
I can and only will speak for myself but I think the way I am and feel is also shared by our regular core group of forum members.
I've been posting the forums since the software was invented and released and even before that as I can trace my posts back to 1994 on the Usenet Newsgroups in both rec.autos.misc and rec.autos.tech
One thing I personally like is when I join a forum is,
A: I am welcomed.
B: I get courteous and helpful replies.
Those are two very simple things but they can be hard to find on other forums. Knowing what I like about a forum, I practice the same thing on this forum. That is, welcome new members and do my best to help them with information that walks them step by step to their goal.
That is the end all, be all of a great forum. Otherwise, it's just a bunch of forum bullies hanging out together for some kind of therapy.
AutogeekOnline is about helping people reach their car care goal in a friendly environment.
So welcome aboard.
Everyone in the forum world likes pictures including me....
I have ordered the CarPro denim and velvet pads from a Canadian distributor and I am waiting on their arrival. I know you use Meguiars, however access to their products is lousy here in Canada so I use Poorboys compounds.
Real quick... and I know it's hard for anyone and everyone to read every post I've made on this forum by "I" remember them and multiple multiple times on this forum on the topic of
The best compound for use with CarPro Denim pads
I have stated that the jury is still out on which compound works the best with these pads and this technique for removing orange peel i.e. removing paint, specifically the paint on the top of the hills for the hills and valleys that make up orange peel.
In fact, at this point in time we live in a detailing world filled with very high tech compounds. Compounds that are NOTHING like the compounds of the old days.
It's also my theory or hunch that some of the more advanced compounds that are popular today may NOT be the best match for leveling orange peel with Denim pads but in fact, more of the old style of rocks in a bottle type compounds actually will be more effective for this first step.
I have not used a lot of Poorboys compounds and polishes, others can chime in on their experience but I do know there are still rocks in a bottle type compounds available and this is where someday someone will step up to the plate and do some testing and then share their results.
So give the Poorboys compounds a try, they may work very well. IF not try to find some compounds based on older technology.
My hunch is having larger abrasive particles sandwiched in-between the hard surface of a denim pad and the hard surface of the paint will work BETTER to knock off the tops of the hills as compared to many of the hi-tech compounds where the abrasives particles are microscopic in size and the compounds themselves feel like Jergens Skin Lotion and not a gritty compound.
Just a hunch...
My plan will be to
  1. buff with the velvet pad (approx 3000 grit equivalent) SSR3 (M105 equivalent) at 6000 speed,
  2. then buff with SSR2 on an orange pad at 5000 speed,
  3. then polish win SSR1 on a white pad.
  4. Buffer is a dual action porter cable.
I've tried the Velvet pads and one thing for sure... they are safe. So safe that any noticeable or effective cutting will come from the abrasives. Remember, CarPro intended these to be used with a rotary buffer so a more powerful tool would increase the cut of just about anything slapped onto a backing plate.
If I were you I would definitely test the Velvet pad first as I always tell my son,
"You don't know what you can do until you try"
And it could be the combination of this Velvet pad, the product, the tool and your technique will work on this paint system.
If that doesn't work then jump right over to the Denim pad and repeat and see if there's a visual difference that takes place faster.
As for the speeds you listed, I might spread my compound out using a the 4.0 setting on the Porter Cable but after that it's pedal to metal. Bump her up to the 6.0 and start making slow passes. Just don't lift the spinning pad off the paint of splatter will go everywhere.
I like the name Demon Pad better than Denim Pad. I'll give you credit for that one. :D
Paint hardness is always an unknow factor -Jason Rose
I always give Jason credit for that quote as it very accurate and I never steal other guys stuff but just the opposite, I always give due credit where credit is due. I don't see this in our industry but that's how I operate.
Here's what I think... you're going to find the Velvet pad is just to gentle and after some testing you're going to switch over to the Demon Pad.
But test first and let us know as this will benefit others into the future.
Regards
...Wes
I'd try the second most aggressive Poorboy's compound you have with the Denim pad and after making about 8 section passes wipe off the residue and inspect.
I'd also place a tape-line down so your eyes can more easily gauge changes.
If that's working and working fast enough for you, (that's two things), then duplicate this over the entire panel.
If it's not working or not working fast enough then jump down to the more or most aggressive compound you have and test in a new place and then inspect the results.
Looking forward to the progress for this project. I'd also like to see a full shot of the Willys!
A bit more background.
After my first clearcoat, I had areas of transition (misted overspray) so I wet sanded 2000grit and buffed with DA, orange pad, SSR3 but I could not buff out some scratches which I'm pretty sure came from wet sanding (doh). So I resprayed and now I have some very fine textured orange peel. This is not a show vehicle, I am learning, so that's why I would consider machine sand and wool rotary buff, however, I am getting a bit tired of repainting - I have painted this panel twice and another test section 3 times (to get a correct paint match and overcome a bad supplier suggestion of using single stage paint first - that was a disaster - cannot buff single stage metallic, so it has to laydown perfect from the gun, not forgiving enough for my skill level). At this point I would like to be finished and put the hood back on.
Lastly, my hood is very flat and so are the fenders on my "flat fender" jeep, so it's ideal for buffing without vinyl tape.
On the advice of the Poorboys guys, I have tried one pass with the DA, orange pad, SSR3, speed 6000 to see how well the compound knocks down this peel and it didn't do much.
I will post some "before" photos shortly. Then get on to the velvet or denim pad.
Shhh, there are somethings we need to learn by experience....:buffing:
Haha, It was a typo! but I like it too:righton:
Yep... that's the problem with single stage metallic paint. You can't sand it or buff it as you'll be sanding directly on the metallic flake and then after you buff on the paint you will completely change the look of the paint and either have the blotchy look or tiger stripes.
Foam pads won't remove orange peel as the foam compresses and conforms to the shape of the orange peel.
The idea behind removing orange peel is to ONLY remove or knock-off the tops of the hills and leave the valleys alone.
That's why a when hand sanding the fastest way to remove orange peel or surface texture is to hard block the paint.
When machine sanding you use a sanding disc with no foam interface pad or foam backing on the sanding disc. You want a hard, non conforming sanding surface as this only cuts the high points.
There is one thread in the forum world where this guy shares a picture of before and after where he removed orange peel by ONLY buffing the paint and not sanding. This was with a wool pad, a rotary buffer and an old school compound. Here's his article and the picture,
Can orange peel be removed or lessoned by just machine compounding?
If you need a hand with the pictures let me know...
Ok, time for an update.
I ordered and received the denim and velvet Carpro pads.
First I tried the denim pad on the my DA portercable with Poorboys SS3. After 3 separate runs with 6-8 passes I still was not satisfied. See photos belows.
Fender:
Hood:
I decided to buy a rotary buffer - got the Makita 9237CX2 - sweet machine, quiet, slow startup and I found one locally on sale. So my thoughts were, if the orange peel removing pads were designed for the rotary buffer, then I would likely get the most out of them on a rotary machine, since the DA wasn't cutting it (pun intended). Ok, I know the warnings everywhere "The Makita 9237CX2 is a powerful circular polisher and should not be used by a novice detailer"and I'm about as newbie as they get, however I painted this and I can repaint it if I have to. And to make all you pros out there cringe evern more, I don't have a paint gauge. But I did spray 3 coats of clear on the hood and 5 on the fenders. Funny, I always wear a lifejacket in my boat.....
Here goes. 600 rpms with denim pad and Poorboys SSR3. Two passes and looks okay. Switched up to 1500 on last pass and worked pretty good, however I gots some pretty significant swirl marks now, bordering on circular scratches, maybe I picked up some contaiment? Dang. Well I cut the orange peel down but now I have these marks to remove. The fenders were near completion as they didn't have the bad swirl marks but the hood needed some more work. See posted photos.
Fender: (Im pretty happy with the fenders now)
Hood:
You can see the swirl marks on the right side of the reflected florescent light:
Back to the DA with an orange foam pad and SSR3. Nada. No go. Still got the marks. Then I had an epiphany, try the velvet pad on the DA with Meguiar's Heavy Cut M0416 (8/10) (I can't find Ultra Cut M105 here and wasn't patient enough to order it). Still couldn't get the swirl marks out. So I put the velvet pad in the rotary buffer on 900rpm and wow did that work nice. My take away from all this is the SS3 doesn't cut and isn't as good a lubricant for the Carpro pads as the Meguiars was. So I followed up with Poorboys SS1 white foam pad for the best shine and those photos are pending. Stay tuned for them.
Ok, I can't show the final photos yet. I cut through the clear coat in a spot test. Not enough to damage the basecoat, but I need to re-spray the clear. Then go from there. Oh well I can hone my "non orange peel" spray techniques.
Before I slip away for a while to re-spray, I want to clarify something. This job is my "test". My jeep was painted in 1994 and had some pretty bad scratches and horribly sunbaked fat pinstriping. I started by repairing the paint on fender, cowling and underside of the hood and it turned out so nice, I decided to tackle the top of the hood. So far I have:
1) painted the hood with single stage (metallic) paint and didn't like it – couldn’t get an even texture that was shiny, and you can’t sand or buff metallic single stage
2) painted the hood with basecoat/clearcoat - got a bad laydown of the basecoat due to novice paint experience
3) Wet sanded and repainted basecoat/clearcoat, basecoat turned out great but got bad orange peel on clearcoat
4) buffed out orange peel with a variety of pads, products and polishers
5) cut slightly through clearcoat in small test area, but need re-spray of clearcoat.
What I have learned:
1) paint stores cannot always be trusted to make good recommendations - single stage metallic is very difficult for a novice to spray and it cannot be buffed – that’s what they sent me home with the first time
2) spraying metallic paint is tricky, need to keep the gun in the same orientation for metallic laydown and not too wet or metallics sink into the paint
3) my orange peel issue was likely caused by two factors a) insufficient paint volume (not wet enough) due to nozzle size of 1.0mm when the spec recommended 1.4mm (I used a touchup gun, next time I use the production gun) and/or b) too long of flash time which create a texture when the solvents in the new coat attack the old coat
4) Not all glazing putty is equal. Do not, every again use single stage putty. Always use putty that requires hardener. Single stage putty never cures, so the solvents from the primer wick in and cause the putty to shrink, leaving an divot blemish that can be seen after bc/cc
5) Do not, repeat do not use lacquer based primers. They never cure and much like the single stage glazing putty, they get attacked by the solvents in the topcoat. I was lucky to realize this before topcoating and was shocked to watch the week long dried lacquer based primer wipe off easily with paint thinner – yikes.
6) my DA is the older non-XP portercable, with does not spin as well as the newer ones, which may be why it was not as effective with the denim pads
7) Mequiars Heavy Cut Cleaner works better that Poorboys SS3 on the denim and velvet Carpro pads. I’m thinking there’s a better lubricate in Mequiars because when I clean the pads the Meguiars product is very slippery and harder to clean. With the low volume acceptance of these pads, better lubricant probably helps
8) my DA process works nice for polishing with Poorboys SS2 and SS1
9) rotary buffing with Carpro velvet and denim pads can work very well and are possibly less aggressive that wool pads (haven’t tried wool yet). I found lower speeds of 900rpm worked well – not sure if 1500rpm would be necessary.
Any insights or counter observations are welcomed.
Re-sprayed the clearcoat on the weekend and it went pretty well. Very slight orange peel, however I got a few drips to sand out and some dirt contaminants entrained in the clearcoat. I bought a 3M Trizact 3000 grit pad and would like to use it. My plan is to block sand out the drips by hand, sand out the imperfections wth Trizact 3000 wet in my DA, then buff with a wool pad in my rotary, then DA polish for shine. I need some input on:
1) Which DA should I use and what speed for the Trizact 3000? I have an air random orbital sander (variable speed adjustable), an older portercable 7424 and a brand new Flex XC3401. I’m thinking the air sander would work best, but what speed? I will be using the pads wet.
2) With the wool pad on the rotary, which product should I be using – like how aggressive a cut would I need? On the scale from 0-10, 10 being Meguiars 105, which should I start with? Also, what speed 600rpm?
3) Lastly, generically how much faster should I be moving the rotary pad vs the DA (which I have experience with and understand the DA arm speed). Also, the DA usually gets 6-8 section passes – how many section passes does the rotary typically get.
Thanks in advance.
