Just picked this up yesterday from walmart for a little less than $7. Heard great things about it and the DUB line came out not too long ago, so I though I'd give it a try.
I haven't cleaned my tires/wheels in a good month or two, so I used some Meguiars APC.
Look at all that grime!
As you can see it gives your tires a very wet look.
Pros:
-Has a "High", "Medium", and "Low" setting on the nozzle, so if you have low profile tires, you can choose the low setting and you won't get it on your rims!
-Smells like oranges! I personally think it smells great, but to each their own. If you're spraying this in a closed environment, then the smell may be a bit overwhelming.
-The shine is great! It gives it a very wet look and doesn't look greasy. It's comparable to Meguiar's NXT Tire Shine.
-Fairly cheap at only $7.
Cons:
-The durability isn't great. Expect it to last only a few days. If it rains, then a few hours.
