Just talked to someone at Duragloss and they said:
1. You can use even more than one ounce per gallon for added lubricity.
2. Just about PH neutral (you could even wash your hair in it).
3. Designed not to strip wax or "polish".
~Drew
Duragloss 901 is an excellent car washing shampoo. I use it, among some others. It depends...if you know what I mean (So many choices).
Being just about PH neutral sounds, and probably is, very nice. Same goes for the: Designed not to strip aspect.
But, I've often wondered: If a car washing shampoo is so "mild"...even to the: "Could even wash your hair in it" mildness-level...How much 'cleaning ability' does it actually have? That meaning: What road/airborne contaminates will it effectively remove from vehicles' surfaces....especially during
a single, once around, car washing session.
Doesn't mean I won't use them...Just makes me a little curious, that's all.
As someone at Duragloss stated to you:
"You can use even more than one ounce per gallon for added lubricity."
Does this claim of additional lubricity (with additional 901 product added per gallon of water) also equate to more, (perhaps stronger?), or, thorough, 'cleaning ability'? What will changing the "recommended dosage" do to the PH level? Would it then have "stripping wax/polishes" attributes?
