mwheberger
- May 10, 2009
- 5
So my roommate works at Carquest and has given me access to any Duragloss products to try. So I got some and will be applying by porter cable for the first time. Here is what I have:
1. swirl remover #671
2. #501
3. #601
4. #105
I am confident that I will apply in this order, but how would you go about applying these and how long would you leave each product on the car before removing? I have read some say that the #601 and #105 should be put on using "straight lines" as opposed to the traditional circular application. Is this correct? If so, then obviously I wouldn't be able to apply either the #601 or #105 by machine. Logic tells me to apply the #105 by machine so it can be worked into the surface more than just sweeping it on top, not to mention that it would be applied more evenly.
2. #501
3. #601
4. #105
