PA DETAILER
- Mar 5, 2011
- 6,005
- 236
[h=1]Formulated with a complex blend of nanoglass ceramic particles[/h][h=2]Safe of paint, glass, vinyl wraps, and other non- porous surfaces[/h][h=2]Provides extreme gloss, durability, and slickness[/h][h=2]Simple, easy to apply formulation[/h]
For an extreme wet look!
Duragloss Nanoglass Ceramic Spray Sealant is the next evolution of the famous Duragloss “Wet Look”. Formulated with a complex blend of nanoglass particles, Duragloss Nanoglass Ceramic Spray Sealant is designed to impart properties of ceramic with each application. Duragloss Nanoglass Ceramic Spray Sealant provides extreme gloss, durability, and slickness with each application. Duragloss Nanoglass Ceramic Spray Sealant is free of abrasives and is safe to use on coated and uncoated paints, as well vinyl wraps and other non-porous surfaces.
DURABLE! Who said you can get a durable protection from a spray application?
Duragloss Nanoglass Ceramic Spray Sealant isn’t some generic spray wax. Just as the name implies, Duragloss Nanoglass Ceramic Spray Sealant harnesses the power of ceramic protection and blends it into a durable, user-friendly product.
SLICK & GLOSSY! Create a slick, glassy gloss in a matter of minutes!
With advanced formulations, comes advanced gloss! Duragloss Nanoglass Ceramic Spray Sealant creates an immersive glass-like gloss on all paint types. Thanks to the nanoglass particles in Duragloss Nanoglass Ceramic Spray Sealant, you can enjoy a slick, ultra-hydrophobic finish!
SIMPLE APPLICATION! Keep it simple while keeping it shining!
Don’t overwhelm yourself with complex product application. Keep it simple with Duragloss Nanoglass Ceramic Spray Sealant. This spray-applied product gives you the glossy benefits of a ceramic, without the hassle of application. Already have a ceramic coating installed? Even better! Duragloss Nanoglass Ceramic Spray Sealant will enhance the gloss, durability, and slickness with each application!
DIRECTIONS:
Should be here soon.
DIRECTIONS:
- Adjust nozzle to fine mist.
- Apply to a clean, cool surface one section at a time.
- Wipe until dry.
