Pretty much what he said...there are some other non-AG coatings that are pretty friendly too. Posh Angel has some easy to apply coatings as well.From what I've read so far, McKee's 37 Paint coating is the easiest to apply & remove. I've also used it and it IS very easy.
The newest version of CQuartz is basically wipe on a panel, wipe off the panel. Let cure. Enjoy for several years.
Prep work is pretty consistent across the board with nano coatings. The real differentiation comes with the actual application process. Some coatings require a lot of attention to wipe off times, type of towels used, ambient conditions (temp and humidity), etc etc etc.
These are my favorite coatings when "ease of use" is an important factor....
22ple - All are VERY easy to use. HPC and VX3 are my favorite (in that order)
GTechniq - CSL is great. As long as you know how to use it, it is very easy. Wipe on, wipe off. Let it sit and you'll have issues. (This is my all around favorite coating at the moment)
Optimum - Gloss Coat is a breeze. Apply to panel, let it flash, gently remove high spots, move on to next panel.
Hey Zach i just got csl and exo 3 today. when i decide to use it can you tell me if it is ok
to wipe off with a suede towel? i know the instructions say to use a microfiber towel. what would be your recommendation for this coating? and would you use the supplied applicator or a suede applicator on a block?
Blackfire Crystal Coat.........Im the MAN
I've had a bottle of this sitting around for a few months... looking forward to trying it out.How about Gyeon Can Coat. Sort of an entry level coating.
