Edge Pads vs. Lake Country
Whitethunder46
So, I pretty much know the difference between the two, but what do you all prefer?
Also may want to note that I want something durable for the pads and the PC, for I plan on using the PC about 15 hours a week for customer vehicles. I've heard things of the backing plate overheating, so is the Edge pads a safer choice?
Edge pads are true detailers choice. They last a little longer, and you can easy detail things like under spoiler. I really wanna get those myself for Christmas.
Im not trying to put you on the spot but how can you give an opinion like that if you dont, or havent, even owned the Edge pads?
I cant comment on the LC pads, just got my sets in this week, but I did have a couple problems with the E2K stuff when I had it. Had two adapters fail and although Edge is a EXCELLENT company and have great customer service I felt that I truely had to try the LCs to find out what I really want to use in the future. E2K stuff works great.... I had a streak of bad luck I suppose. Ill be playing with my LCs very soon. :awesome:
Heard that form Justin, man.
You cannot go wrong withe the EDGE2K system.
I've used their system everyday for the last 5 months. These are the mosr durable pads I've used. I still used one yellow pad that has seen over 125 cars!!! They all get washed in the machine on gentle cycle.
Now, just like with any other product, there has been an issue or 2. Had a problem with my adapter. Called Aaron at EDGE and the NEXT morning there were 2 on my door step! He told me that he didn't want me ever loose any business over a product failure so he sent me a back-up. This customer support blew my mind and others can testify too. I will never knock another pad or product ever. LC makes good pads. I'm just telling you my experience with EDGE since I do this everyday.
Also, remember you are getting 2 pads in one.
they are both great products, and I was a diehard LC pad user for the past several years only. I recently got the EDGE kit after asking "why should I change" and given an open opportunity to test. Their are some real benefits to their system also. Two sided pads is the most obvious.
I have been using the LC VC pads and the classic Edge pads (the velcro sided ones) for a bit and prefer the edge - they seemed sturdier and have more choices of ppi. I recently got the Edge 2000, they seem to be constructed very nice, but have yet to use them.
Friend turned me onto the Edge 2K system, and love it. Love the quick release, dual sides (perfect for our suv's), and the balance it gives the PC (much less vibration then normal). Plus Aaron made me custom 4" blue and orange pads to try out months and months ago, they deffinitley came in handy for spot buffing.
Edge for all of the above especially ease of changing. It will save time and better maintain your momentum when you're "in the zone". LC is good for backup or a second dedicated machine.
I'm a big believer in the Edge 2000 system as well. I was formerly using LC and Meguiar's pads. I've now sold all those other pads. The Durafoam used in the Edge pads is certainly top notch. It maintains it firmness and abrasive level after many uses. Plus, you can't beat the many, many, many advantages of having the quick change adapter and the dual sided pads. The most pronounced difference is the lower level of PC vibration because of the automatic centering of the Edge pad. Plus there's no velcro in the Edge 2000 system. This means no worrying about delamination, the velcro wearing out, the pad flying off, or the backing plate breaking.
The forthcoming 4" pads will add yet another advantage to the system. I like to use 4" pads in tight areas or for spot buffing. However, with my LC pads I always had to change to a smaller backing plate to use the smaller pad. Since there is no backing plate in the Edge system there's nothing to change which saves me time. All the Edge 2000 pads no matter what the size use the same adapter. So, changing pad size is a snap!
HI Guys,
I just want to add that we make velcro pads as well that are second to none. We do feel now that velcro is obsolete as a technology in buffing pads because you really need the pads to be centered in order to work properly, but LC has nothing on us because we have the same exact foams, and have a velcro system like theirs except our super durable glue will never come off. I can't speak for the backing plates because there are so many failures and they are made to fail eventually. Our adapters are guaranteed for LIFE, so even if you ever have a problem, ie you drop the buffing and dent the adapter, we will replace it free of charge. Doubt anyone else will give you that deal.
The Edge said:
HI Guys,
I can attest to the velcro pads being better, imo, than the LC pads. They hold thetr form over time better and are constructed top notch. I have read also of members (cannot remember which board:o ) where their adapter failed for some reason, they contacted Aaron, at Edge, directly and he sent TWO replacements in the mail. Service, service and service.
That was me... Aaron at Edge took the time to talk to me over the phone for a while and then sent me replacements. Havent had any problems since. It has been said before many times... Edge does care a lot about their customers. They make a great product and Im glad I have Edge pads in my arsenal.
Is there any chance of bottoming a pad out and the quick connect contacting the paint? I really like the looks of these pads.
Tic
The Edge said:
HI Guys,
That was another big question of mine after reading all of this. From reading and research I know exactly what LC pad to use when and w/ what compund etc., but wandered if they coincided with Edge.
Thanks a lot for the info guys, looks like I'm going to be ordering the PC w/ Edge 2K kit and then Pinnacle XMT compounds and glaze. Then lotttttts of little things and misc. products.
Right now my list is around $650, hopefully autogeek will let me spend that much!:D
For all the members, again thanks a lot. You guys have been more than helpful with all my questions and newb needs!
Lets see, Avenge, I am disappointed that even with the new adapters not failing you still are switching lines. I really don't know why your adapter failed but it has been very rare that one fails, and even if it does, they are guaranteed for life and I think we have shown we do make good on that claim.
Ticman,
See the pic below and search for others with the same fears. You will find that you cannot hit the adapter.
Ticman,
I never said I was switching lines... I still have your Edge pads and adapters in my detailing supplies. I sold a few of them (6" pads) and now have a set of 8" Edge wave pads to use with my Hitachi... I did keep a few 6"ers to use with the rotary too. To be honest I thought the thing to do with the rotary was to go with 8" pads... I didnt know it was so popular to use 6"ers or I probably wouldnt have sold any of my 6" E2K pads. Being a rotary noob I jumped the gun on selling my 6"ers and swapped for 8"ers... then through some research found out that the 6" pads were actually more popular to use with the rotary. Oh well.. thats what I get for jumping the gun, at least I have my 8"ers now... and few 6"ers left.
Ive always been curious about the LC 7.5" VC pads (one of my best buddies uses them) so since Ive heard nothing but good about them I thought Id try them for the hell of it, so I ordered a few.
Ive learned a lot in the last few months about all the different lines of detailing products and I figure WTH Ill try a few I havent tried yet and see how I like them.
But like I said.. Im not switching, I still have E2K goodies in my arsenal.
Oh, GREAT! my mistake, I read your post to say that since the problem with the adapter you were switching to LC even with the replacment adapters. I see now that you did say they would still be in your arsenal, and that is GREAT!! Thanks!
