Edge Waffle or Regular?
FMINUS
I am thinking about trying the Edge system when my LC runs out, but then I have over 15 LC pads I dont think they will EVER run out.
And after being reassured by Edge that any defects would be replaced throughout its LIFETIME, I've decided to do it NOW!
I have a PC and I am wondering if I should go for the Waffle weave or the original?
i really liked th waffle...seems to work the poduct in better...i wish i woulda got more waffle pads...but im deff. getting them for my rotary
Will the
Cyclo DoublePrecision™ Foam Pads
Work w the Edge adapter?
WAVE for my rotary.......PLAIN for my P.C....;)
Also, whats the purpose of owning both a PC and rotary?
FASTER RESULTS WITH ROTARY, AND MORE PRECISE IN TIGHT AREA CORRECTION WITH THE P C
AS FAR AS WAVE FOR ROTARY?? HEAT BUILD UP REDUCED, CAN USE LARGER PADS FOR LARGER AREA'S,.......... AND REGULAR FOR P.C.s IS JUST A PERSONAL CHOICE AND USE OF MUCH SMALLER PADS............
I just ordered the 8" waves for my Rotary. Should help vent any heat.
I usually like flat for PC, but I do have a 6" wave yellow and 6" wave orange (will use both on the Rotary as well). I like the wave 6" orange because the orange foam is very very dense and firm, so it can get lopsided easily. The wave version helps keep it flat since there is less foam to go back to normal.
Even though my rotary is here, I still use the PC to apply wax/sealants/and some glazes.
for compounding/polishing i like the wave pads...the green, orange, and yellow...i get less pad hop and the slower release of the product is a good thing.... for applying waxes/sealants/glazes i like the flat pads better as they waste less product....as far as pc vs rotarty using the flat pads and wave pads really dont differ much in final result...if you want to get more cut out of your pc use the 4inch cyclo pads...the pc can rotate those pads much easier and bogs down less...
Will the Cyclo pads work w the Edge Adapter?
So ur saying if using the hook and loop, the 4 inch pads will work better as well?
the cyclo doubleprecision pads are pads that use the same edge adapter as the pc.....
the hook and loop ones look like this...
both types of pads will work well on the pc...what is nice about the edge system is you dont need different sized backing plates for 4/5/6/etc inch pads...
