How do you back tape?I've had great success by airbrushing burn thrus like this then put some clear over it. A lot depends on the paint metal flake doesn't airbrush very well. Do a google search for touch up paint supplies. I bet you could even brush it on then sand it down with 2000 to 3000 grit finish with clear. Remember to back tape if spraying so as not to create a hard paint line.
Fold back the masking tape so overspray can actually get under it. Pretty much the opposite of traditional masking that creates a hard line. Let me know if you can't find a picture of this with a google search and I'll post one.
Since most don't have airbrush supplies I'd try a paint pen first. Build up with thin layers. It really is an easy fix. Won't be perfect but will be close.
Can't find anything, only on door jamsl.
since i dont have any airbrush equipment, should i try the dupli-color scratch fix 2n1 pen for the factory color and clear?
ThanksYea the door jam stuff I found on YouTube isn't good. Try searching How to Back Mask Base / Clear by jimmo4life May 14,2012. Pretty good instruction, can't say the painters technique is very good but covers the back masking and even spraying blender.
I like to peel back the back masked tape with each pass of base and clear. It just softens the line for less blending when done.
Now keep in mind originally we were talking about a buff thru on a door handle. Concepts are the same it's just a much smaller repair. When learning the rotary I caught a hood edge on my white Explorer and burned thought the clear and base coat. Being a white car only a few years old it fixed right up and you couldn't even tell. I'd much rather have a door handle blemish cause everyone always looks at the hood never at a door handle!
Let me know if this helps. I don't have anything set up to paint right now but the next time I break out the airbrush I'll take pics and/or video for posting here. I could set up a sheet metal panel and demo this for you this weekend if you need more info on this technique.
