Engine Cleaning Help
Regency
Hey so I've detailed engines before but I got my second car and its a jeep srt8 and doesn't have an engine cover and the engine is gross is it just like regular engine cleaning with no cover??
yeah I usually just clean that the same way as anything else. of course be careful not to spray much on any electrical stuff. just spray with cleaner, hit really quick with the wash mit and soap here and there, then rinse with hose and medium pressure water. let air dry for 20 minutes then dress. no problem.
Alright cool guys thanks a bunch I'll take pictures when I'm done and the flash makes it look clean if you look at my over flow tank you can see grime
awesome! What method(s) did you use to achieve those results? And what products?
Excellent...What products did you use?
Just chemical guys all clean + and a couple brushes
:iagree: Looks Great
Thanks!
All clean plus just spray scrub let it dwell then rinse take off all of the foil and baggies dry with a waffle weave then start it up then hit the highway and then it will be all dry then I used silk shine and chemical guys metal polish
Hi-res shots:
Here's some actual pics of the detail
