FlairBarstar
- Nov 20, 2014
- 11
Hi autogeek people, i would be needing opinions from you; i have a bmw z4M-coupe and i rarely use it. I made a mistake... I started the engine with the CAR COVER installed and left it for 45 Minutes on idle. When i came back, i noticed the hood is very hot and the kidney grills is having hard time getting some air into the intake because entire car is covered. I opened the hood and there is no steam or smoke. I touched the engine and its not that hot but its warmer than usual. When i turned off the engine; the fan is still running. i got confused on whats happening because engine is turned off and fan is running. When i turned the engine back on; the engine seems fine. So i turned it back off again and the fan already stopped. Im just concerned if the engine got hurt or damaged. Any opinions would be greatly appreciated. Thank you in advance!
