Evo X RS one day blitz
AutoGenie
One of my regular clients owns a few Evo's and uses some of these alongside his tuning business. One such car is this modified RS X that needed the underside, paintwork, glass and interior decontaminated, cleaned, and protected prior to the Winter lay-up
Exterior
-Pre-contact wash with Autosmart G101 and Serious
Performance Citrus cleaner
-Rinsed
-Jacked the car up and cleaned the chassis with a variety of brushes and scrubbed the floorpan and arches, following but a high pressure rinse
-Dropped the car back onto the deck and cleaned the wheels, tyres, brakes and arches with Autosmart car shampoo and SP Citrus as well as Car-Chem iron remover for the alloys
-Rinsed again before a two bucket wash for the paintwork and glass using Autosmart car shampoo and re-rinsed
-Decontaminated to remove bugs, rubber from tyres, brake dust and tar using Car-Chem iron remover, Autosmart Tardis and Autosmart G101
-Rinsed again
-Dried with uber yellow towels
-Hand polished with Autosmart Evo 1 finishing polish
-Paint sealed with SP1000p for protection
-Glass sealed with Angelwax H2go
-Tyres dressed with Autosmart Highstyle
-Alloys sealed with SP1000p
Interior
-Mats removed and shampoo'd with Angelwax fabric shampoo
-Carpets shampoo'd and vacuumed dry
-All plastics dusted, cleaned and treated with Angelwax ANgel
-Seats vacuumed and cleaned using Autosmart Bio-Brisk
This car is one that I'm hoping to get the chance to machine polish in 2014, as it's been used hard for a couple of years now and the battle scars are starting to show! It's certainly no show queen :D
God I can't wait to get back in an Evo... We don't get the RS here in the states. Is the Evo X RS, Similar to the VIII RS? Does it still have manual windows, no wing, aluminum roof, stiffer dampers, etc?
Taken from the MLR
As Evo X GSR, plus:
- Gravel brakes
- 16" Alloy wheels
- Basic non-bucket seats
- Black door handles and wing mirrors
- More basic plastics and panels inside
- No armrest on centre console
- Rear bench seat more basic, cheaper carpets
- Electrically adjustable door mirrors (non folding)
- Rear mechanical LSD
- Halogen headlights
Less:
- Brembo brake calipers
- Enkei alloy wheels
- High level rear spoiler
- Air conditioning
- S-AYC
- Electric fold door mirrors
- ABS
- No rear wiper
- Passenger airbag
- Passenger sun visor
- No boot liner
- No Hid lights.
- No intercooler water spray
- No HDD Satellite Navigation System
- No Rockford Fosgate Premium Audio and Music Server
The RS was available with a "tarmac pack" which included the following GSR options:
- Brembo brake calipers, 4 pot front, 2 pot rear
- 350 mm 2 piece Brembo front discs
- 18" Enkei alloy wheels
- Yokohama A13 245/40/18 tyres
- Chassis brace
Other factory options included:
- Inconel turbine wheel TD05H-152G6-12T (non cost option)
- Single DIN
- Intercooler water spray"
This one has the following bits
Forged 2.1 Engine built May2013 (1200 road miles) (Stroke is 2mm longer that stock)
Carrilo H Beam Rods (Carr bolts)
CP Custom X Forged Pistons (10:1) - High Comp
ACL Race Bearings
Cosworth Heads Studs
ARP Main Studs
Piper 280 Cams
Ferrea Competiton Plus valves
Latest timing chain & timing gear installed
MHI Billet Turbo (Ball Bearing)
JMF Tubular Manifold (With Zircotec ceramic coating)
Janspeed 3" tig welded exhaust
C-Tec High Flow Modular Down pipe
Pace Intercooler
CBRD coolant radiator
Ross Sport Custom IC Pipes
Ross Sport Intake pipe kit
Uprated coolant radiator & hoses
Motec M800 ECU with advanced features & Active Knock Control & Wideband control
Motec MDC II Diff controller
Greddy Profec B Boost Controller
Ross Sport Evo X Fuel System
AMS Fuel Rail / Feed Kit
ID 1000cc Injectors
Exedy Twin Plate Clutch (New May 2013)
Std front diff / Transfer case - RA Super Traction Also Available
New Std Rear diff (Installed November 2013)
Gearbox Fully Striped, cryogenically trated & Micropolished assembled with Needle bearing C/Diff)
Ralliart bushes throughout
Ohlins DFV Suspension
Cusco / Eibach ARB's
White line roll centre kit & tie rod ends
Alcon 365mm Front Brake Kit
Alcon 343mm Rear Brake kit
Pagid RS29 Pads
Ralliart Servo Delete Kit & Uprated Brake cylinder
HEL brake Lines
Uprated Clutch Cylinder (CT9A Evo)
OMP Steering wheel / Boss Kit / ACD Button & Loom
Ralliart Mats
RSZ1 Wheels 18 x 9.5 with 265/30/18 Yoko AD08
ARP Extended wheel studs
Retrofited Airconditioning
DAB Radio / CD with JL Audio Speakers
Light weight race battery
Bride Lowmax Seats (Not pictured)
Ralliart Carbon front Splitter
Tuned!! :)
