Exterior Plastics Detailer/Protection
5js
I have a new vehicle and am looking for a recommendation for a exterior plastics detailer/protection. I see a lot of products reviewed for renewing exterior plastics - but I'm looking for a product to detail and protect plastics on a new vehicle.
McKee's 37 Plastic Trim Restorer
Has never done me wrong. Excellent durability. Does not streak or run when it get's wet. Now is the time to apply it while the vehicle is new.
Is your trim brand new and already perfect? You can keep it that way with McKee's 37 Plastic Trim Restorer! Prevent all of the downfalls listed above by simply protecting your plastic surfaces from the get-go! McKee's 37 Plastic Trim Restorer is a must for new cars – whether you have a ton of trim or not! Preventing a problem is always easier than trying to correct that problem later on
If it's a new car I would suggest CarPro Dlux or Gyeon Trim. Will last much longer than the other products. For older vehicle that may need something more to look good again, I would go with the sealants instead of a coating.
I applied WETS to my brand new truck, all the trim beads water like its been waxed. Very happy with the stuff we will see how long it last.
I second McKee's Trim Restorer. I applied it on my car late last fall (seems like it may have been Thanksgiving, but I don't know that for certain). I was doing a rinseless on my car last night, and for the first time noticed the trim looking a bit washed out. I pointed it out to my wife, who asked me what the hell I was talking about - She thinks it looks great!
So, in my opinion, McKee's will last @ 10 months. But according to my wife, it might last indefinitely!
Has there been a 'bake off' between the various exterior trim sealant products? I'm sort of a fan of WETS esp after the last BOGO sale.
WETS and McKee's 37 Trim Restorer are either identical or very very close. I have both and really can't tell which one I'm using if you cover the label on the bottle.
I have no comparison. When I started, I picked a brand, and based off of one product, I chose McKee's. That is my starting point for any product I need. A few things in their line have been OK, but I thought I could find better, and I've switched a couple. But a few, the Trim Restorer being one, have been so good, I don't see the point in experimenting.
Based on reading, there may be something that is better. But my guess is that that difference would be so marginal it doesn't make sense to spend my time evaluating.
This is my exact observation.
I did a side-by-side on my wife's Wrangler, and I could not tell any difference.
Sounds like WETS or McKee's 37 Trim Restorer are the recommendations. Just curious how those compare to two other products I have seen recommendations for.
How would these compare to Sonus Trim and Motor Kote Sonus Trim & Motor Kote, acrylic protectant, black plastic protectant, engine dressing
How would this compare to 303 Aerospace Protectant? I see here Auto Trim & Molding Guide: clean & protect exterior vinyl, rubber, and plastic trim and bumpers. that Mike recommends either Wolfgang Exterior Trim Sealant or 303 Aerospace Protectant.
