Faded interior plastic
hoyt66
Active member
I picked up a used car (2003).The plastic on the inside top of the door panel is
faded almost white and it should be black. Is it salvageable? I cleaned it and used
BF interior protectant on it but it didn't even dent it. Sorry no pic. Thanks
Is pimp my ride still around? They can screw it up for you.
I wonder if that solution stuff will work for interior as it will exterior? I would see if you can PM cee dog and see if he can send you a little sample so you do not have to drop a decent amount on that stuff and not working well?
Just to add I used it on some all but white plastic trim and it made it look like new. Doc posted similar results as well.
I would also suggest giving it a thorough scrubbing prior to applying it to ensure you've removed any debris or oxidation...
Excellent point Bobby!!
Whatever you use to clean it be sure to clean with alcohol after.
Some APC and other cleaners can leave something behind that can affect the durability of Solution Finish.
I, too, will have to give 'Solution Finish' a try!
@OP:
IMO...Be sure to use the "TEST SPOT" method with the 'alcohol-cleaning', and this SF-product, as well...
Just as my dear friend...
was fond of saying:
Please keep us apprised of your results. Thanks!
