Faded trim, question about ceramic coating
JChastain
Guys,
My 02 Tahoe's plastic trim is faded and I was wondering if ceramic coating with dlux would bring the finish back and keep it that way permantly? If not what other options do I have? Thanks
Most ceramic coatings are designed to bond to paint. You could use a plastic restore type of product and then keep it all together with a sealant on top.
Dlux says it's for plastic and wheels. Not sure how it works though..
Haven't used Dlux, but if it's safe for plastic it wouldn't hurt to try
Curious if I need to use something else prior to it to restore color..
If you clean everything really well, the plastic would be ready for Dlux. Applying a conditioner type product before the Dlux might impede or change the way bonding occurs, which is no good.
You will want to clean it thoroughly before applying the trim coating. DLUX or Gtechniq C4 will certainly darken the trim and keep it dark for a long time, however it will not be permanent. If your looking for a permanent solution you could do what I did with a Tahoe we used to own. I picked up Krylon plastic paint in a satin black finish and painted all the trim black (previously a gray color).
hQKSkh1iO7-Rf1zWKNGpcyfjmEt2bQjsoXu7yDuxRiZUdj3WIAFmz4kHOkJt_2Es9JpjQ6Dazile2pVwb8muwv9LLyNAhD-mTSGPV8ZdOKeVUBJApPvFpa6V2DqTIlXXMLIEcaK7FwD9FQBSWye3cS1oZYC7EBg3--bczYWpzX5oJk_Y-xWMBBKXxY-RWs29JzOyJ6GQ6WdoPyZcoLho1NPMlryO6H8hMjadnE1TVrms593l7j1EyXL1bNluY6wpmBkjV_cT_SCsbsP2z8mDmjWqcQ2L5aPookwsow5D1ucCzBcDQc-Q1UN3YrhFC6_9Z8zr2bvP6x467c6dPJJHArGMffwi47RYmimDbaVAP3bouuQzWzw4PIptjXDVlUeesC44URg-br3x6Ejlsi2QEc5MrAgHXiGWsqyMCj3Jcd1rLpkWGwu02ODRh0gyJbLmCeHmljaQzI1ijKC89QNQurG_8C3EoLV3trZ0QTXuy85ReY0WFcWfPM2W0saRD2tXhRe2u9-AIOrNLq8IxsoQvHkbfKJ4N2QDyR6507TicnHhmqk_dPwXbKtIWe-LPQnIC1sMKVG9tgHCa1WVmfFV2FSi2lHdMr4Pu1v7h7rukZh0J9EoBIc0=w1200-h798-no
You may want to restore it with Solution finish
Solution Finish Black Plastic & Vinyl Restorer, trim restorer, black plastic restorer
The seal it in with a trim sealant like this one
Wolfgang Exterior Trim Sealant, rubber trim sealant, rubber protectant, exterior trim products, metal sealer
Or coat it with something like this for longer longevity.
Gtechniq C4 Permanent Trim Restorer, rubber trim sealant, trim restorers, gtech c4
I found GTechniq to be easier to work with than DLUX. Both work well.
nothing is ever going to be permanent, if it was everyone would have it
I found GTechniq to be easier to work with than DLUX. The key to using Dlux is super thin coats, work small sections and do not keep wiping over especially when it starts to flash. Both work well.
:props:
I would go with the C4.
It works really well and so far (2 years almost) still looks like new on windsheild moulding.
Wurth makes a Trim Coating (really a paint) that is self etching and it resores to factory black.
Used the Wurth on the plastic inner fenders and after 1 year still look like new (this is a very caustic enviroment for a finish but not exposed to UV, which causes the fading).
I agree with you on C4. Working great for me on the front and rear window trim of my grand prix as well just as you stated. Also have it on all the trim of my 2002 Camaro.
I should try this wurth stuff on the fenders of mine.
Looks great Kevin. How is the paint holding up?
It held up great for the year I had the vehicle after doing this. I ended up selling this vehicle then so I am not sure how it held up after this, however we did end up doing the same thing with my wife's Traverse LTZ that we ended up with. I don't know why GM always put grayish trim on black vehicles, it looks terrible. This has been painted for over a year also and I never do anything to it other then wash it.
OgGck1aEawP1cBBCVXTpw71wr50a1wRjwajt_-CCAA8-PdQeuaQlXH6S-fdsssrA2yJXfJGuGZJitCbepPFopVKeYzQhkj_bfA8eyAzPxA2ga4W30NcG85xi6mmatsx4TLdjwRrmspEzh-_HkBQ_xzqRuteYt01M8YowMNXclRGYmhcTljfgXehlwjlf20YGFRfpd27lCvs-6dcmbinh3dZ5ow21MlSmngWVQga3gCxS6aGoLZ0ZT1QRHGjrIvKOt2az7xt1p48GOYBFR-sipgQBiEK-HjGn-y7PDkfvJk3GRyX9_N8WpL__Eybdde4_gn-Zvqr1nbw7fW2a7O1IR3G1gMMa66ml-DuZHaPizU1edi__vXZorXB1qGevaN7PhN4xorrSYLlum6lchq7IUQ9yLsyanuhVgHt727CM_cFtXS_aZC3TKJl0hQxTuPkYj_SY_assYhYLDkwV8ok4W7tH7fFtDjg3W_d9tJ4gHe5k-ADwkawvVYAMMlVimNJJEsYo2YhaV2QpB3dJiHEi5xXRNdJ2LMz-RSB7I88kciXH_ChjueqmlIcY5icGnC-EK4wHFVYN9Q-j4nvbNerOkYaZCuh3Bk9LyPl08nlf-N1Xk0uOoepw=w1689-h950-no
Here is a comparison to what it did look like before (random photo showing gray trim on bottom)
f2e85551cc099855f12485d07a0e496a_2011-traverse-ltz-black-2010-chevrolet-traverse-black_1024-768.jpeg
