Carpro Reload, ADS Ceramic Spray Sealant, NV Boost. However, I probably wouldn't use those for this wash-clay-seal as they wouldn't be lubricated enough, or be cost effective.
So, and I know this will rile some up because of where this advice comes from, the products recommended, and the ordering of those products, but its a proven combination -
- Wash as normal
- Clay using P&S Bead Maker as the lubricant
- Dry
- After you've finished with the rest of the detail, go back and apply P&S Defender as a final pre-handover inspection wipe down.
The Bead Maker is cheap enough to use in this way, while also offering decent lubrication. Then, topping that with Defender improves the longevity. That's counter to what we've normally been told, ie most durable product first, but for whatever reason it works. In theory, something like 3D Bead it Up or Technicians Choice TEC582 could substitute for Bead Maker, but I've always found Bead Maker provides that wax-like glossiness. Either way, I'd be interested to hear what you go with.
Check out the below video -
