Ok, what is your procedure on filling up foam gun container.
Just read on Autogeek and it says to put soap in first and then spray water. With this you will get less water and just a bunch of foam in container.
I normally put water in and then soap. Close things up and shake just a bit to mix. That way I have don't have to deal with a half empty container with mostly foam.
Thoughts?
Thoughts?
