zarmstrong92
- May 24, 2016
- 11
Howdy,
For the first time in 8-9 years I sadly curbed one of my wheels and decided to take the plunge and do the repair myself. Using a die grinder, I started off with a 400 grit sand paper and worked my way up to 3,000 grit. After the sand paper I used a 3M fine surface conditioning then followed up with Meguiars Ultimate Polish applied by hand. In the middle of each image below you can see the polished 2" section that stands out from the undamaged machine lip. I understand I'll never get the machining grooves back with this type of repair, but there are two other spots on this wheel that had the same repair. While the repaired area looks much better than it did, these repaired sections are much more noticeable in person. I've taken this wheel to three local shops in hopes they can clean it up a bit better and it's too small of a job for them to take.
Surely there has to be a way to get a better factory match? Although I'm not sure if that would come with a new type of metal polish, a layer of paint, or if clear coat would hide it a bit better? There is currently no clear on the repaired areas. I reached out to the wheel manufacturer asking what sheen the clear coat is and they didn't respond Im the MAN
If anyone has any suggestions it would be greatly appreciated! At this point I wish I would've just taken it in to a shop at first vs. trying to fix myself. Thank you!
