Finally! Fault codes and notes from $2,800 check engine light
Don M
Active member
Since *I* basically hijacked my own thread, and people were asking for the codes pulled during the inspection, I'm starting a new thread.
I found the notes from the original estimate, which included the fault codes that popped up.
The codes found were: P0175 and P0172, the notes state: "air is being pulled in by either the front crank seal or the rear main seal. If vacuum is removed from the crankcase the fuel trims are within spec. With vacuum applied, fuel trims go -25%"
This was before the "Engine Power Reduced" warnings cam on.
The car has been at the Camaro Club's recommended shop since Tuesday, he was going to try to get to it early, but his shop is BUSY and he must not have been able to get to it. The scheduled appointment was for this Monday, so I should hear something by Monday evening/Tuesday morning. **Keeping my fingers crossed**
