Finishing polish after fixer
Rifay
Hello sir,
Which products is good for final finishing polish after done with carpro Fixer
1. Carpro reflect
2. Carpro essence
Hello sir,
1. Carpro reflect
2. Carpro essence
Either of those products are great but also depends what you are looking to do with the project. Essence is a bit more expensive than reflect. Essence would be the perfect solution if you plan on doing a coating like cquartz after, and from what I read on the carpro forums it's also fine to do traditional sealants and wax over top also.
Reflect would be good if you want to save a few bucks and still get great results and don't plan on doing a coating.
I personally feel that essence has more gloss and it's not too bad that it has fillers that don't wash out after a typical car wash. So if you don't mind spending the extra I would personally choose essence.
Take your pick. Essence will leave protection behind.
I need only gloss and im not applying any cquartz coating ..
I have to apply collinite wax and carpro c2v3..
Sure you can. There is magic when you use reload after essence if you want to try that.
Ok wic pad is good for essence after follow up with carpro fixer ???
