So I will be doing my first paint correction ever on my vehicle before sealing it. I already bought The Last Cut Compound along with a 5.5" LC microfiber cutting pad, LC HDO blue foam cutting pad and orange foam polishing pad. I plan on purchasing a maxshine M15 DA unless you guys have different suggestions that isn't rupes or flex money. If I am any good at this and actually start doing it as a side gig, then I'll upgrade to a Rupes. I'll be hand washing the car with the 2 bucket method and grit guards. Using Carpro Iron X and then claymagic fine grade before starting the correction.
The vehicle is a 2011 Corvette which is known to have pretty hard paint. The person who sold me the coating recommended I finish the car with Menzerna 3500 and the orange polishing pad but I've heard that it is pretty oily. Somebody recommended that I use carpro Reflect instead but I've been reading that it takes just the right technique, amount of product and proper pad to prevent marring and hazing. As a beginner, I feel like I should purchase something that is easy to use and gives great results. I also would like a finishing polish that is versatile with soft and hard paints. I'm not opposed to buying a different pad for whatever polish I use, if it's necessary. I've heard a lot of great things about HD polish and meguiars m205. Just wanted to get everyone's opinion. Thanks!!
