FinishKare 2180 and Menzerna SF 4000
Swift
  • I'm planning to buy Menzerna SF 4000 polish. Before I buy it, I have question about it. According to Menzerna SF 4000 it has cut of 4 and gloss of 10. FinishKare 2180 has cut of 2 and gloss of 10. After polishing, if I apply finishkare 2180, will the abrasives in sealant damage the good work of polish?? SF 4000 leaves polishing oil, will sealant abrasives, remove the oils and seal the paint or I will have to use IPA?
  • Has one anyone used this Combo? Does it work? How to tell if car care products from different brands gel together or not? Using this combo is making apprehensive for some reason.
Feed back please
If I was going to use Menzerna SF 400 as the finishing polish...I'd go with Wolfgang Deep Gloss Paint Sealant, instead of FK-2180.
You can use 2180 after you have polished with SF4000. No problem at all. I have never seen any cut after 2180 but I know it contains cleaners who will make sure that it will bond properly to the paint.
