Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
Today we received a shipment of one of many new-for-2012 Meguiar's car care products. While all of Meguiar's new offerings for 2012 have been highly anticipated, one of the most talked about is their new Tire & Trim Gel, part of the Detailer Line.
Meguiar's Tire & Trim Gel is a thick, water-based dressing that restores the look to tires and trim. It is designed to apply thin and dry to the touch within minutes of being applied. Because of its thick gel formula, you don't have to worry about it slinging off.
To put Meguiar's new Tire & Trim Gel to the test, I applied it to both the tires and the trim of a Ford Expedition. If you're familiar with the Ford Expedition, you know that it's BIG and has lots of plastic trim. If not cared for using the correct products, this trim will fade and discolor in no time.
To apply the Tire & Trim Gel I used a Cobra Flex-Foam Tire Dressing Applicator. These applicators are big and easy to hold.
Meguiar's Tire & Trim Gel spreads evenly and because of its thick, gel formula, it doesn't get stuck in grooves or raised letters.
Left side is bare, right side has been treated with one coat of Meguiar's Tire & Trim Gel.
Completed.
As you can see it does a great job dressing tires. It goes on thin and only required one coat to achieve the desired low-gloss look. But how well will it fare on trim?
The running boards on the Ford Expedition test vehicle hadn't been treated with any protectants in several months.
To ensure you achieve the best results from any trim protectant, make sure the surface is squeaky clean. I gave the running boards a quick cleaning with Blackfire All-N-One APC and a microfiber towel.
Using the same Cobra Flex-Foam Tire Dressing Applicator, I applied a thin, even coat of Meguiar's Tire & Trim Gel.
The directions state to wipe off any excess with a clean towel.
Completed.
Meguiar's new-for-2012 Tire & Trim Gel goes on thin, dries to the touch, and leaves a slightly-glossier-than-new finish on tires and plastic exterior trim.
If you're chopping at the bit to get your hands on a bottle, it will be available very soon to order. :dblthumb2:
Meguiars Tire & Trim Gel 32 oz.
Completed.
Completed.
