First Impressions of Finish Kare 1000p Hi Temp Paste Wax
akimel
We purchased our glacier blue Honda CR-V in May 2009. I have only used one protectant on it--Ultima Paint Guard Plus. I love this product, principally because of its ease of us. In less than 15 minutes I can seal the paint, cladding, and trim. One single product does it all, and I don't even have to go back and buff off the residue. And UPGP's durability ain't too shabby either. Three to four months would be a fair estimate, based on our experience. It's difficult for me to judge, as I will usually apply a fresh coat of UPGP in mid-summer, simply because it's so very easy to apply. I applied the mid-summer coat in early July, and it was still going strong three months later.
But rather than going with UPGP as my winter protectant, as I did last year, I decided to switch to Finish Kare 1000p, which is known for its outstanding durability. I've had this tin of the stuff for over a year. If I don't use it now, when will I ever use it? And though I am quite satisfied with UPGP's durability, my sense is that five months of winter exceeds its protective limits.
Yesterday I decided to do my fall detail of our CR-V. I washed the vehicle with a double dose of CG's Citrus Wash Clear and then clayed it. I had intended to go over the paint with a pre-wax cleanser; but I simply did not have the energy and time. I then pulled out my tin of 1000p. What a monster tin! The "Big White" indeed! There's enough sealant in it to last me until the next millennium. 1000p has to be one of the best wax values on the market. I opened up the tin with a screwdriver and smelled it. It has a chemical smell, but it's not overpowering in the way, e.g., the smell of Collinite 845 is. I really didn't notice it during the waxing process.
The advantage of the large tin is that it allows one to get all of the foam applicator into the tin and swirl it around. This is a hard wax. My experience with paste waxes have been limited, for the most part, to boutique waxes like Souveran, Fuzion, and Midnight Sun, all of which seem to melt into the applicator pad. Even Harly Wax liquifies fairly quickly in comparison. 1000p is different in this regard.
Based on advice given in various 1000p threads, I decided to pre-moisten the pad with a spray of quick detailer. I think this was a mistake. It made it more difficult for me to determine whether I was actually getting wax onto the pad and then onto the car. Remember, my CR-V is silver blue. It's difficult to tell if any way whatsoever is getting applied to the paint surface. I have to rely on touch and feel, and the lubricity added by the quick detailer just made things more difficult for me, so I eventually switched to a fresh applicator and started over again. Much better.
I tried to apply the wax thin. 1000p's hardness actually makes this easy to do. I worked my way around the vehicle at a leisurely pace. By the time I had finished the car, the wax on the hood had begun to haze. I then proceed to buff off the wax, using my Meguiar's Ultimate Wipe towels. I really like these towels both for quick detailing and wax removal. I have read that some have found 1000p difficult to remove; but that was not my experience at all. It came off quite easily.
I did not apply the 1000p to the cladding and plastic trim. Hence by choosing to use 1000p an additional work step was added to the process: I had to spend an additional 45 minutes sealing the cladding and trim with Ultima Tire and Trim Guard Plus. I really like this trim dressing, though I've only been using it on the windshield cowl, relying instead of UPGP to protect everything else. UTTGP comes with a large foam applicator with foam handle. I confess I was skeptical whether the darn thing would work, but it actually worked great on the cladding. I used foam make-up wedges to apply it to narrow and small trim pieces.
I applied the second coat of 1000p the next morning. I had written Finish Kare and asked them how long I should allow the first coat of 1000p to cure before applying a second coat. They advised 24+ hours. This is contrary to others have heard from Finish Kare on the subject, so I messaged one of my favorite Autopia gurus, Bence. Bence appears to have a comprehensive grasp on all matters Finish Kare. He advised me to wait 12-24 hours. So I sliced the difference and waited 18 hours.
The question everyone wants to know, of course, is: How does it look? Answer: it looks great. But I have to admit that I find it hard seeing an optical difference between the UPGP and the 1000p. I haven't pulled the car out into the sun yet (it's an overcast day), so perhaps I'll see something when I do. Bence also tells me that the look will change after the curing process has completed in about three days. Some folks have mentioned that 1000p makes the paint look like an additional layer of clear coat has been added. I have't seen that illusion yet, but I'll report back after three days to share my observations.
The most important question for me is: Will two coats of 1000p get me through the winter months. Ideally, the protectant will still be going strong in April. We shall see.
I concluded the session by dressing the tires with Surf City Garage's Beyond Black. I think my wife will be very pleased when she returns home from her visit to her mother's.
Cheers,
Al
1000P is awesome stuff! 2 coats is what I'm also doing for my winter protection. Its really durable(lasted all last winter and easily into spring) and too easy not to use.
It does take a day or two for the wax to fully cure but it truly does add a "candy" like coating.
I was wondering if anyone might invoke this refrain. :)
I don't do pics anymore. They do not show perceived differences between protectants--at least, my inexpensive camera does not show these differences. You'll just have to rely on my eyes. :cheers:
000p lasted last winter here and we did have more snow then normal. I washed when I could using ONR once a week sometimes 2 weeks.
Has anyone done a comparison between FK 1000p and Collinite 845 IW in terms of durability?
I have just started using FK 1000P also. The first place I used it was on my rims. So far the durability has been great and it left a very bright, flake enhancing gloss (rims are metallic gunmetal color).
I too am using this for winter protection on one of my vehicles and 845IW on the other. I am very interested to see which one has the best durability. Time will tell.
Final update: my wife loves the 1000p look. She has better eyes than I, and she believes that the 1000p gives a glossier, more glass-like look than the Ultima Paint Guard Plus. I think she's right. If she had to choose between 1000p and UPGP, which she also loves, she would probably choose the 1000p. But she, of course, is not the one doing the detailing.
If 1000p provides the kind of durability to which everyone testifies, it will become our winter sealant. But in the spring I will return to Ultima Paint Guard Plus. It simply saves me too much time and effort.
I have 2 coats of 845. Rochester, NY has crappy winters. Lots of snow and salt. I'll let you know how mine holds up.
Two month update: I applied three coats of 1000p in early October. The car has seen a fair amount of mileage and been through a couple of rainstorms. I've washed the car two or three times since the last coat was applied. The car still looks great. I honestly do not see any decrease in gloss. The 1000p cleans up remarkably well. I am impressed.
Now that winter has arrived, I will be moving to ONR and the occasional visit to the local coin-op to keep the car clean. I'll be interested to see how the 1000p survives the detergents used at the coin-op. I suspect it will simply laugh at them.
I have observed the same, when it comes to washing everything slides off fairly easy with the shine and gloss remaining week after week. I use the FK 425 for a little extra amping, great combo(1000p & 425) for shine, gloss, and durability, not alot of depth but thats okay, it does everthing else so well.
Update Report:
It's been a little over 5 months now since I applied the 1000p to our CR-V. The car has been washed numerous times, including a couple of visits to the local coin-op, where I used the commercial detergents. It's been raining today, so I thought I'd take a couple of photos of the beading.
As you can see, the 1000p is still going strong. I am very pleased with the way this sealant has held up through these winter months, and I plan to use it again as our winter wax for the CR-V. 1000p enjoys the reputation of being one of the most durable sealants available on the market. My limited experience supports this reputation.
Finish Kare 1000p Hi-Temp Paste Wax is an excellent product.
Thats pretty impressive!!! Those are some nice beads especially after that duration of time!
I use FK1000p on the carbon fiber parts of my engine bay. The stuff is amazing. Holds up to the heat, and makes cleaning sooooo much easier.
Based on my experience with 1000p, you can use 1000p year round without a lot of extra work. I can see no reason why AKIMEL couldn't continue to use Ultima Paint Guard Plus on the cladding and use 1000p on the paint. It might be necessary to do the cladding work on one day and 1000p the next but that shouldn't be a huge problem. If it is, Optimum Spray Wax is getting excellent comments and can be used on the cladding. Given the weather conditions described by AKIMEL, I'd probably spray the cladding down with OSW once a month during winter.
From my experience, 1000p, is easily removed from the cladding that's properly cared for if any gets on it. I use a soft bristle shoe brush for this.
As for the lack of depth of 1000p, 2-3 coats of Finish Kare's 2685 Pink Paste Wax works very well. It too, is easily removed from cladding.
I might add there's a good deal on Amazon for the 2685 as of this writing. The normal cost of 2685 is $17.99 but you can get 3 cans of the 2685 for the same price. Given how far this stuff goes (I'd guess 40-60 cars per can), I'm fixed for life.
Its hard to remove if you use even the slightest bit more than needed, but it really does bring the shine out of my GTI. Really good stuff, especially considering the massive tub you get for the price
