First paint burn
I have an 8 pass rule for myself, 8 passes without any pressure, inspect, if more sanding is needed then I do 4 more passes then inspect.
Really love the Unigrit paper, a little safer.
After my passes wet sanding I then compound , if the scratch or defect is still there oh well, it is what it is.
The drill was a bad mistake, I know it's too late and not trying to make you feel worst but saying it so that others not make the same mistake.
We're all here to help another and we do:)
Sorry man:(
I'll follow-up and take a few better photos when I get my friend to fix it. I didn't want to bother him over he weekend. The trizact disks are meant to be used with a 3" orbital buffer but I had used them with my power drill as I can set the speed based on how hard I pull the trigger but I may spring for a Griot 3" going forward.
