First polishing experience with the 3401
Xcessiv
Hi,
I'm very new to the detailing world and just bought a Flex 3401 (dual action). Here's the paint under 2x 250w bulbs:
Here's what I bought:
1x Flex 3401
2x Grit Guard Bucket Insert
1x Riccardo Clay Lubricant
2x Lake Country CCS 6.5" Blue
2x Lake Country CCS 6.5" Orange
2x Lake Country CCS 6.5" White
10x Tornado Buffing Towel
2x 100% Sheepskin Mitt
1x Poorboy's Super Slick & Suds Wash
2x Snappy Clean Foam Pad Cleaner
Trim tape
1x Riccardo Clay
1x Menzerna SIP
1x Menzerna Nano
1x Poorboy's EX-P
1x Poorboy's Natty Blue
I was wondering...
1) With the SIP, what speed/pad should I start with? My initial plan was speed 5 and white pad, followed by speed 5 and orange pad if it doesn't work, followed by speed 6 and orange pad with slightly more pressure if it doesn't work.
2) With the Nano, what speed/pad should I start with? My initial plan was speed 5 and white pad.
3) What about the sealant & wax? With the 3401 or by hand?
4) I saw some videos on youtube with the PC, they suggest making reallllly slow movements up-down-left-right to ensure that the polish breaks down. Since the 3401 is different, I guess the rule is also different? What's the optimal movement speed for each phase?
Thank you!
Regards,
Yan
I used the Flex last weekend and started at 2 on the dial to spread. Got the machine up to around 5 as a maximum. Your white pad start is a smart move although that pic shows some serious swirls.
Again 2 to start .... once polish worked in you can run almost up to the top speed to jewel the paint. Use a finishing pad as possible unless you used orange above, then white will be needed.
hand
you will still work small areas and overlap quite a bit, the Flex wants to get away at higher speeds so hold on tight.
Zoran I swear ... anything Flex and you immediately take note. (j/k)
The Flex at high speed can catch you off guard when working the top of the car or areas when two hands are not always usuable. Sometimes the Flex wants to jump/jut and "hold on tight" was a metaphor so it wouldnt cross the entire panel and go scooting down the trunk / hood or other paint items.
