So it has been a long time and a few leases now but wanting to do a more thorough clean-up on a newer car (2020) again. My first one was back in maybe 2008 using a Zaino kit - I still found some of my old Zaino stuff as a matter of fact.
Thanks mostly to this forum, I have assembled the following and thinking to use in the following order:
For the weekend clean-up:
McKee's 7 - 290 coating prep wash
Q2M Gyeon Iron Remover
Nanoskin Clay Towel and Glide lubricant
McKee's 7 - 360 AIO Polish
PB's Black Hole Glaze (if needed)
Wolfgang Silica Spray
Maintenance Items: (for later use as needed)
Wolfgang Uber SiO2 wash
Wolfgang Tire & Wheel cleaner (plan to use it up above as well but will use it as needed on regular basis)
Meguiar's Gold Class wash
Meguiar's Hybrid Ceramic Wax Spray (currently on it right now post-purchase in March)
Car is a 2020 and relatively clean. It should not need much for decon but sat for awhile with dealer and I can tell they washed it so there are very fine micro scratches in some areas. You can see these only in very specific lighting (hold your head at this angle and move a certain way type of scratches). It is my DD but I work from home so it probably falls under the garage queen classification. It will get to experience the CO winters in a few months but that doesn't mean I'll have to drive it if weather is bad.
I will do the polishing by hand in the needed areas (hood, roof, trunk). My goal for this first one is cleaned up and protected and beating the clock with 90+ degree sun. I know there is more depth I can do by adding additional products but hoping the above will get me to the clean and protected level I am seeking - I'm not yet convinced those micro scratches will be removed since I'll be doing it by hand but not planning to go out and buy a machine.
Anything crazy here or off? Anything I will surely regret if I don't add and be buying next week anyways?
Feed back please
Feed back please
