NewFinishingDude
- May 26, 2020
- 2
Hi Guys,
I'm brand new to the forum and I figured I'd ask for some advice on fixing deep scratches, rust and some kind of paint chipping stuff going on. I've been doing a ton of research and gathering all the tools recommended to get the job done right. Or at least I think so...
Scratch 1
#1 The first scratch here is down to the primer and into bare metal in some spots. My question here is should I use bondo gold body filler or just glazing putty because while the scratch is deep, it isn't very wide. Or is there a better way to fix this? I'm also curious if I should sand the scratch before applying filler or not. If so, what progression of sand paper would you recommend?
Scratch 2
#2 I'm not sure how this happened to the hood, maybe too little clear coat from the factory? There are a few areas like this that I assume you want to use body filler, sand, glazing putty, filler/primer, paint, cut, polish, finish right?
Scratch 3
#3 This is a rust spot that I noticed where I'm guessing a rock jumped up and caused a chip which eventually rusted. Unfortunately, it's right on the lip above the windshield and will be a challenge to sand and finish. Any advice on this one?
I bought the Milwaukee cordless rotary polisher, 3M perfect it compounds, microfiber towels, bondo gold filler, glazing putty, wool pads, 3M pads, proper car code spray paint etc. I still haven't bought any sandpaper yet as I keep hearing different thoughts on the progression I should do for my case. Any suggestions on the best way to fix these issues would be greatly appreciated as I'm totally new to this but love to fix things myself and save some $$ even if I have to spend some on tools. Thanks for the advice in advace!
Scratch 1
Scratch 2
Scratch 3
