Recently, I decided to use a iron remover on the car in case there was metal contaminates. I washed the car and spray Optimum FerreX on the car. The instructions indicated that the spray should be left for a minute and then rinse off. I tried this on two different car, a new car that needed to be rewax any way and an older car with existing wax job.
The product smells rather nasty in a industrial solvent sort of sense. The product sort of gels and run down the surface. Any water beading would immediately flatten out. Unlike the video, I did not see any purple particles not even the rims, just a lot of white stuff. Both car are red and perhaps the purple doesn't show against the red background. Keep in mind, I had clean the car earlier, so perhaps there weren't any particles left.
The instruction said to leave on for a minute and then rinse. It took a lot of water to rinse the product off, it foams when rinsed. I can't tell if it did anything, though it did stripped the car of wax. I accidentally forgot to rinse two of the wheels so that the product dried on the rim. I notice this an hour later and rinsed it off. There seems to be no lasting damage (so far).
I had to re-wax the car. It's not clear if the product actually did anything.
Paul
Paul
