first time using porter cable 7424xp and m205
flatlinerz
Member
hey guys
so its going to be my first time using porter cable 7424xp and also using m205, I will be putting on cquartz for the first time so I just want to make sure everything right. I have my 5 inch backing plate and lc white pad, whats the best way to apply m205 to the car, what speeds and passes? Been trying to youtube a few videos any good guides or advice please will be much appreciated
thanks guys
Test spot, a good estimate is speed 5, 6-8 section passes. Do you have everything to prep the surface and ensure it's bare before applying CQuartz?
I use 4 pea size drops to the pad, I start on speed 2 to spread the polish over a 2x2 area then kick it up to speed 5 and make 4 passes keeping my arm speed slow and moderate pressure.
Very easy to wipe off, I love 205.
Make sure you're happy with the test spot before moving on, you don't want to have to do the entire car again later if not satisfied with the results.
What are you using to remove M205 oils to leave bare paint for your coating?
I like to rewash with cg cwg before Applying lsp.
Sent from my SAMSUNG-SGH-I777 using AG Online
Thanks for that
so after I polish the car should I wash the car again or use a MF to buff it off?
