I bought the griots newest third gen polisher and finally got around to using it today. I washed and clay bar'd my car and then whipped out out my polisher. I did a test spot and found out my optimum compound II with a yellow pad was going to be my best bet. Before I had a lot of swirls, and don't get me wrong, they aren't as bad now as they were, but there are still a lot of swirls that remain. My product was dusting so much that it was just covering my windows completely. I used the towel method of cleaning the pad on the fly along with using a pad brush that came with y kit. The product was also caking onto the pad and was complelty dry.
I primed the pad completely then did 3 pea sized drops and did about. 20x20 area 3-4 passes. And there are still a lot of swirls in the sun. My wife came home and said, "I still see swirls, that was a waste of money." I also used an orange 6" pad that came with my kit and it worked better than my 5.5" flat lc yellow and orange pads. Still caked up and left swirls behind, but it was slightly better.
Do you think I need to buy some better pads or a compound with more cut? I use the 6 pack of 5.5" pads for $35 from here, maybe those aren't good enough for my clear? Idk, but i need to figure something out because there are still swirls. I was thinking of heading to autozone tomorrow to pick up m105 and try that.
Any ideas?
Any ideas?
