fisrt da project
mreed2483
So I got a DA and used it on my wife's 2003 Escape. I used Pinnacle shampoo, nanoskin on the DA, XMT 360 with a light cutting pad and then topped with Megs NXT 2.0. Also I put aquapel on the front windshield and rear window.
Oh and I used Armoral Outlast Trim restorer on the black molding.
Thank you. The roof had oxidation but the 360 cleaned it up really well. My biggest peeve is that around the washer prayers there is a "stain," for lack of a better word, from the washer fluid after the hose came off. When I get it ready for winter I will try to get it off better.
I used the armoral because I had a $5 rebate from it. It doesn't streak like mother's back to black and is easier to work with. Water beading on it is great too. We've had a lot of rain lately and it is still holding up well.
Your welcome, as for the wiper fluid stain you may have to remove the sprayer nozzles off the hood so you can have a better access though its nice to save a few bucks when you can though once you finish that look into some semi permanent like Dlux its less maintenance and has uv protection
Thank you. Not bad I thought for a 2003 with 160k miles on it. Just need to out some touch up paint on rock chips on the hood.
