carenthusiast
- Nov 17, 2013
- 111
I found the HF DA in local HF store where I live.
I have read many reviews and concluded that the machine is worth giving it a try at under $60 (minus 25% discount coupon).
The question is: what foam pads should I buy for it? Can I put just any 6' foam pad on it?
I have read reviews of foam pads sold for this DA and most people complain that they shred into pieces due to backing plate being too large (stated to be 6", measured at 5,3", while the foam pad is only 5").
I see some place order for the Velcro backing plates and immediately replace the OM backing plate on HF DA.
Do I really need to do that?
I will use it for ONE TIME application of polish and sealant and may not be using the DA for the next few months until it's time to remove the old sealant and put a fresh coat of wax for the spring.
Anyone with experience of dealing with HF DA pads, please share your thoughts on best fixes.
Thank you!
Carenthusiast
Thank you!
Carenthusiast
