The clear coat on my hood is past saving. So, other than the cost of a can of clear and some time, there's nothing to lose. I did the prep - clean, 1500 wet sanding, clean, dry, tape...
... Then paint.
I've probably used over 1,000 cans of spray paint in the in past 40 years (I repainted my first bike purple!). I'm pretty sure I got the application right:
- Three medium coats (first one a bit lighter than the next two)
- Can 8-10" from surface
- 1/3 overlap of the spray
- No starting or stopping on the panel
I knew after the first coat, something was up. The surface just looked dull and splotchy. I figured, I'd lay just a bit more down - not heavy, just a little slower on the passes. Nope - still dull and splotchy. After three coats, not much changed. The paint looks thick. It looks like it's curing properly. It just looks like crap - splotchy, dull, heavy orange peel.
I'm guessing my high-tech paint booth... my open garage (Land Cruiser half in; half out) allowed the high temps and (the culprit) high humidity to screw things up.
I've never had a rattle can do this. But, I've never used this type of paint - the hardener, etc. Lesson learned (if I'm right on the humidity) - wait 'til October to paint in Atlanta.
Now, the fix. I'm thinking (what got me into trouble initially) I can let the clear cure for a week (more than necessary, but it'll be a week before I can get back on it) and get out the polisher and start with a fairly aggressive compound and work my way up. Basically, just do a 3-step paint correction as if this were just old, dull paint.
But - and it's a big but - I am totally guessing on ^that^. Any tips?
Thanks!
... Then paint.
Thanks!
