Demonizer
- Nov 30, 2013
- 26
Well... I finally got to use my Flex 3401 DA. As a newbie to this kind of detailing/paint correction - I thought I would share my experience along with a couple questions on what I learned using my Flex 3401. I have never used any kind of DA polisher or specialty compounds - just auto parts store cleaners & was - hand applied.
First - why I chose the Flex 3402 - It had the best reviews, and I thought there was something to the forced rotation DA, also I thought my paint was worse than it was (so I found out when I used it) - Forced rotation just made more sense to me.
I was procrastinating using it because it was bigger & heaver that I thought it would be, and I thought its was overkill for me & I would wreck my paint or something. This is absolutely a professional tool for rigorous use - way more that a hobbyist like me would really need - I even thought about returning it for a smaller Griots or something - but I kept it - waiting for the right time to use it.
My car is a 1967 Mustang I built - took 4 years. Paint is all PPG Deltron base & 2021 clear - and its BLACK!
Was cut buffed out nice & flat. After I put the car back together I had been leaning on it & wiping it down with regular towels (before I learned about Microfiber) which marred up the finish pretty good. Not to mention all my car buddies & the "use an old cotton diaper, or soft terry cloth towels" well, these leave plenty of scratches. Now I have an arsenal of MF towels from Microfiber Madness on down.
Couple weeks ago I was up North at a 3 day car show where it rained all three days and I had to dry it off with the hotel towels - YUP - I said the hotel towels - YIKES - so, the paint was in bad shape with swirls & towel scratches you can see a mile away -
So its time to fix all that - out comes the Flex.
I got all the color pads in the LC Hybrid 5" lineup - 2 of each, except the white pad where I got 6 of those - most reviews on AG said the white was the most "universal" pad that I would probably use the most.
Products are Wolfgang Uber Compound, Total Swirl Remover, Finishing Glaze, and the Deep Gloss Paint Sealant - all 3.0
After reading many, many posts & watching Mikes videos, I started with the least aggressive combo I thought might work - White pad & TSR.
STEP 1 -
Did a test section - Flex on speed 3, White Pad, TSR - WOW! 4 passes with just the weight of the Flex got rid of 95% of all defects - that was awesome.
The Flex was very easy to use, easy to control and smooth with very little vibration. I worked the paint for 7 hours straight with no hand fatigue. Glad I kept it - and now I would not trade it for anything.
So now 95% of all the defects are gone. Rather than go after the last little scratch in my test area, I wanted to complete the whole process to see how it really works and to what degree the first step of compounding really needs to be for a car I like to drive allot & will most certainly get regular usage defects in it again.
The uber compound did not seem necessary.
So - on to STEP 2 - Polish
First I used a black (no cut) pad with the Glaze, speed 3. didn't seem to make a very noticeable change.
So, I tried the White pad again on speed 3 - WOW! The paint really came alive and cleared up even more of the defects & "haze" left from the TSR. - Great! - So now I would say it was hard to find any defects at all.
STEP 3 - Seal
Black Pad, Sealant, Speed 3. Very easy to apply
waited 45 min.
VERY Easy to remove - which was GREAT - after removing the TSR & Polish steps, it was a nice relief to be able to re,oce the Sealant so easily.
End Result - AMAZING. Yes, there are a couple of random light scratches left - but nothing anyone will find, and the overall look of the car is amazing,
Went to the car show tonight & everyone thought I got a fresh paint job - was more comments about how pefrect my paint is than usual - so yes - it was a huge improvement that anyone can notice. - even without chasing every last scratch.
Now, some Questions for the experience guys.
1) During the compounding step with the TSR - I started to get swirl marks left from the DA. I traced my progression of the little 2x2 panels I was working on & found that when I had the FLEX on speed 5, with light pressure applied - it left the swirls. If I worded a few passes at Speed 5 with some light pressure applied, THEN switch to Speed 3, with 3 passes & no pressure but the weight of the Flex - no swirls - just incredibly smooth & clear black - Does this sound right?
2) Step 2 - Polishing. The black pad did not yield much of a change/result. Using the White pad on speed 3 made a very noticeable change in the finish, and worked out any hazing left from Step 1 - really got the the depth & clarity back. Guessing the Polish needs either a harder pad and/or a lightly aggressive pad (like the White) to work the paint?
Well - there you have it.
The Flex 3401 very hight recommended - and easy to use!
to anyone who posted things about the Flex, pads and/or Wolfgang products - THANKS - I probably ready your post!
STEP 1 -
STEP 3 - Seal
waited 45 min.
