New-ish boat combo?: Flex 3401 + Rupes Blue Coarse Foam pad + Captain’s One-Step + Captain's Boat Coating?
Hello Mike (and others)!
I am looking to polish a 1-year old 30ft. Grady White with light-blue colored gelcoat. As the boat is only a year old, the gelcoat is in visibly great shape and doesn't need heavy cutting. There are a few superficial bumper/buoy scuffs, but nothing major at all. I was looking to use my Flex 3401 with a Rupes Blue Coarse Foam pad and the Marine 31 Captain's One-Step to do the polish.
I have a few questions:
The boat sits in the water from April - October in New Jersey so I'm looking for a durable sealer that will last as long.
Thanks in advance!
1. Does this seem like a good combo for a relatively new boat?
2. Is the Rupes Blue Foam pad too aggressive for this to be a one-step process and will I have to follow it up with a softer pad?
3. What sealer would you recommend? I'm looking at the Marine 31 Captain's Boat Coating with UV50. Will I need to wipe the boat down to remove oils from the Captain's One-Step prior to using the Boat Coating?
Thanks in advance!
