Im going to be buying a flex and seeing as all i have is 5.5 pads i will also need new pads. Does anyone have experience with the flex and the Kompressor pads, or would i be better off sticking with the 6.5 pads?
1 orange, 2 white, 2 grey and 6 mfs at minimum.
OK. I was under the impression that you needed 3-4 pads of a given type to do a whole car. How long do pads last, and is this the best deal on Kompressor pads AG has offered?
How long do the pads KEEP, in an AC environment?
If you spur the pad after each panel 2 would be enough. And a couple grey/blue for final polishing. If you keep your pads clean/dry and store them in a zip lock bag or container, they will last for years, but with heavy use, they will wear down.OK. I was under the impression that you needed 3-4 pads of a given type to do a whole car. How long do pads last, and is this the best deal on Kompressor pads AG has offered?
Lets say I was getting 12 pads. Blue or black for most jobs? How does 4 black, 4 white, 2 orange and 1 gold and 1 purple sound? Is it likely I will really need purple? I do need to buff out colorsanding scratches on my car. Scratches are 2500 now, but I may go to 3000. Will an orange pad be enough to remove 2500 sanding scratches? Will the gold really be useful in saving me time in jeweling? I will be doing a lot of work in the sun. I was thinking of going for Poorboy's SSR1, SSR2 and possibly SSR 2.5. Would Optimum be a better choice as far as working in the sun, getting great results with the Flex, and economy? What spur do you suggest for foam pads?If you spur the pad after each panel 2 would be enough. And a couple grey/blue for final polishing. If you keep your pads clean/dry and store them in a zip lock bag or container, they will last for years, but with heavy use, they will wear down.
Will the stock Flex backing plate work with the Kompressor pads, or do I need the Lake Country 6 inch backing plate?
